Hi John,
Matthew and Stephen suggestions are right on track. Either using the Search Cursor, or the Get Count will be identical in performance. Example using Search Cursor:
mxd = arcpy.mapping.MapDocument(r"C:\Projects\\Municipality.mxd") df = arcpy.mapping.ListDataFrames(mxd)[0] list = [] with arcpy.da.SearchCursor(lyr, ["OID@"], "OBJECTID > 0") as cursor: for row in cursor: list.append(row[0]) del cursor count = len(list) if count == 0: ..... del mxd
Example using Get Count:
mxd = arcpy.mapping.MapDocument(r"C:\Projects\Municipality.mxd") df = arcpy.mapping.ListDataFrames(mxd)[0] for lyr in arcpy.mapping.ListLayers(mxd, "*", df): result = arcpy.GetCount_management(lyr) count = int(result.getOutput(0)) if count == 0: ..... del mxd
Both techniques will/do work, but in my experience the performance is not identical between the two. For small to medium datasets (~100,000 records or less), the performance can be quite similar with the arcpy.da.SearchCursor and arcpy.GetCount_management. For larger datasets, I have seen GetCount outperform cursors by 3 to 10 times.
Jason Scheirer speaks to why using a GP tool is faster than a Python cursor with larger datasets: Re: How to determine number of records using arcpy.da.SearchCursor.
