I know this is an old thread but I was wondering how you got round this? I have a similar problem where I am looking to divide property points into polygons with an equal number of points. It would be great if there are any suggestions or anyone can share their experience on this.
Thanks in advance for your help
Charlie
If anyone still looking for a possible answer, I wont be around the bush.
In Pro there is a tool called Build Balance Zones. It can take your point layer and use its algorithm to create concentrations based on the number of zones you tell it. I believe there is a limit to the number of zones. Like most things available, its not perfect and every time to run it, it will create a different version. There are other settings you can configure to get a better, accurate concentration. I used Trimmed Delawney Translation and checked Compactness. You can then draw around the concentrations your polygons or use a template to select areas based on the concentrations.
Hope this helps
