Do you add the shapefile zip file to arcgis.com or publish the service from arcmap?
Can you share your feature service publicly? Or share the shapefile you created it from? You are trying to edit in arcgis online, right?You need ArcGIS Desktop 10.1 to publish services to ArcGIS Online.Thanks,Mike
Looks like you've found a bug. I can reproduce the problem against your service. I was also able to edit the attributes in ArcGIS Explorer Online, so it's definitely a problem with Arcgis.com website. The feature service seems to be working properly. We'll have to investigate this. Can you keep this service running for a bit? ThanksMike
