Hi there,
I am not sure if this is possible in Survey 123, but does anyone have a work around where you might have several basemaps (Tile packages) that are in all different locations, can you define the extent in the builder so that when you select a certain map its already set out a specific extent. Im finding that when we are out in the field and we change basemaps, its so zoomed out that its hard to zoom into the map. I realise that you can set a home location for one basemap, but can you set bookmarks for all of the basemaps so that they are not so zoomed out.
Thanks in advance
