Hi, if i do a site with arcgis api for javascript 4.8 and use public available arcgis basemaps and tiled services. İs it free or not. Question is simple answer simple please
Adem,
I am a esri customer (not an esri employee). Strange if your are an esri customer then where is the point in this thread? If you have an AGOL subscription then you would not be concerned about using the API for free, as has already been explained in previous replies.
Go on with this attitude, i am customer not you. And you lost one already.
Well good luck with that attitude. You have heard my advice, esri JS API Software Developer, and another user but your are unwilling to listen.
To put it simply you are asking for legal interpretation of esri terms of use (no mater how simple you think this question is). The GeoNet community is for providing help advice and code samples, etc from community members and we can not speak for Esri on legal matters. No one is try to give you the run around but what you think is a simple question could actually be a very complex question based on may factors that esri customer support is trained to handle.
i asked a simple question you say bla bla bla bla bla bla.... if i go to esri office what is this blog for ?
my question is simple
This is my site. is it free or not yes or no ? Dont say bla bla bla dont copy paste anything yes or no ?
<!DOCTYPE html><html><head><meta charset="utf-8"><meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no"><title>Intro to SceneView - Create a 3D map - 4.8</title><style>html,body,#viewDiv {padding: 0;margin: 0;height: 100%;width: 100%;}</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.8/esri/css/main.css"><script src="https://js.arcgis.com/4.8/"></script>
<script>require(["esri/Map","esri/views/SceneView","dojo/domReady!"], function(Map, SceneView) {
var map = new Map({basemap: "streets",ground: "world-elevation"});
var view = new SceneView({container: "viewDiv",map: map,scale: 50000000,center: [-101.17, 21.78]});
});</script></head>
<body><div id="viewDiv"></div></body></html>
If your app is being sold for profit, then you would need the ArcGIS Online deployment Plan.
However, If you already have an ArcGIS Online Organization, you do not need to purchase the deployment plan.
See: Terms of Use - FAQ | ArcGIS for Developers
You may be able to supplement buying the ArcGIS Deployment Plan if you have an ArcGIS Enterprise License as well. I am not sure on this.
As Robert Scheitlin, GISP suggested above, it would be best to contact Esri directly to seek answers to these questions. Esri's Licensing can be quite confusing at times.
I hope this helps.
Chris
The bare minimum is to sign up for a free developer account.
Licensing & Attribution | ArcGIS API for JavaScript 4.8
Excerpt:
While you are developing and testing your application, you can use the free Essentials Plan of the ArcGIS Developer Subscription. Before deploying your app in production, you will need to ensure that your application meets one of the following requirements:Uses data and/or services from ArcGIS Online. Requirements for deploying an app that uses Online are described in the Production licensing requirements.Uses data and/or services from your licensed ArcGIS Enterprise.If the app does not use ArcGIS Online nor ArcGIS Enterprise, you must ensure that you have the correct licensing for your use case. If your app is for public, non-revenue generating, non-government, non-commercial use, the free Essentials Developer plan is sufficient. If you're going to generate revenue or are using the app for government or business purposes, you'll have to purchase a paid ArcGIS Online Deployment Plan when you're ready to deploy your app to production (even if your app does not use ArcGIS Online data/services).As long as one of the above criteria is met, no additional licensing is required when deploying apps built with the ArcGIS API for JavaScript to production.
The only correct answer is for you to contact your local esri office and explain your use case and they are the only ones that can give you the answer you are looking for. Simply put we can give you an answer to what we think but esri customer support is the only ones that can give to a definitive answer.
More detail. Doing this site is free or not ?<!DOCTYPE html><html><head> <meta charset="utf-8"> <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no"> <title>Intro to SceneView - Create a 3D map - 4.8</title> <style> html, body, #viewDiv { padding: 0; margin: 0; height: 100%; width: 100%; } </style>
<link rel="stylesheet" href="https://js.arcgis.com/4.8/esri/css/main.css"> <script src="https://js.arcgis.com/4.8/"></script>
<script> require([ "esri/Map", "esri/views/SceneView", "dojo/domReady!" ], function(Map, SceneView) {
var map = new Map({ basemap: "streets", ground: "world-elevation" });
var view = new SceneView({ container: "viewDiv", map: map, scale: 50000000, center: [-101.17, 21.78] });
}); </script></head>
<body> <div id="viewDiv"></div></body></html>
it is a simple question. i use javascript api and esri's maps not other things. is it free or not.
this is not answer
There is no simple way to answer this question about legal use of the API without much more details on your use. See this thread.
https://community.esri.com/thread/172234
Your best way to get a 100% answer is to contact your local esri office.
