When using AMD code, is it possible to use the older widgets that were written in the legacy code (using dojo.provide, dojo.require, and dojo.declare)? Or do the widgets also need to be updated to AMD?If it is possible to use the older widgets, what would the code look like?
This code works properly <!DOCTYPE html> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <title>TOC</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0px; font-family: helvetica, arial, sans-serif; font-size: 90%; } #leftPane { width: 280px; overflow: auto; } /* this line hide layers when out of scale for the inline TOC */ #scaleDiv .agsTOCOutOfScale { display: none; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true, packages: [{ "name": "agsjs", "location": location.pathname.replace(/\/[^/]+$/, "") + '/agsjs' //"location": 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.04/xbuild/agsjs' // for xdomain load }] }; </script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/"></script> <script type="text/javascript"> var map; var urlSEFCRI = "http://egisws02.nos.noaa.gov/ArcGIS/rest/services/biogeo/SEFCRI/MapServer" require([ "dojo/_base/connect", "dojo/parser", "dojo/ready", "esri/map", "agsjs/dijit/TOC", "esri/arcgis/utils", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function ( connect, parser, ready, Map) { ready(function () { //parser.parse(); }); map = new esri.Map("map", { basemap: "oceans", showAttribution: false, logo: false, center: [-80.2, 26.67], zoom: 11 }); map.resize(); layerSEFCRI = new esri.layers.ArcGISDynamicMapServiceLayer(urlSEFCRI, { id: 'SEFCRI' }); map.addLayers([layerSEFCRI]); connect.connect(map, 'onLayersAddResult', function (results) { var toc = new agsjs.dijit.TOC({ map: map, layerInfos: [{ layer: layerSEFCRI, title: "SEFCRI", slider: true }] }, 'tocDiv'); toc.startup(); console.log("Set TOC"); layerSEFCRI.setVisibleLayers([0]); }); connect.connect(layerSEFCRI, "onLoad", function () { map.setExtent(layerSEFCRI.initialExtent, true); }); var resizeTimer; connect.connect(map, 'onLoad', function (theMap) { connect.connect(dijit.byId('map'), 'resize', function () { //resize the map if the div is resized clearTimeout(resizeTimer); resizeTimer = setTimeout(function () { map.resize(); map.reposition(); }, 500); }); }); dojo.connect(layerSEFCRI, "onLoad", function () { map.setExtent(layerSEFCRI.initialExtent, true); }); } ); </script> </head> <body class="claro"> <div id="content" dojotype="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;"> <div dojotype="dijit.layout.ContentPane" id="leftPane" region="left" splitter="true"> <div id="tocDiv"> </div> </div> <div id="map" dojotype="dijit.layout.ContentPane" region="center"> </div> </div> </body> </html>
<script type="text/javascript"> dojo.require("agsjs.dijit.TOC"); dojo.require("esri.arcgis.utils"); dojo.require("esri.dijit.BasemapGallery"); //dojo.require("esri.dijit.Popup"); dojo.require("esri.map"); dojo.require("dojo.data.ItemFileReadStore"); //dojo.require("dijit.layout.AccordionContainer"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.TabContainer"); dojo.require("dijit.TitlePane"); dojo.require("dojo.fx"); // needed if use jsapi 3.0 dojo.require("dojox.grid.DataGrid"); </script> <script type="text/javascript"> var map; var identifyTask, identifyParams; var urlSEFCRI = "http://myserver/ArcGIS/rest/services/biogeo/SEFCRI/MapServer" var layerSEFCRI; var tasks; var clickPoint; function init() { var popup = new esri.dijit.Popup({ fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])) }, dojo.create("div")); map = new esri.Map("map", { basemap: "oceans", showAttribution: false, logo: false, infoWindow: popup, center: [-80.2, 26.67], zoom: 11 }); loading = dojo.byId("loadingImg"); layerSEFCRI = new esri.layers.ArcGISDynamicMapServiceLayer(urlSEFCRI, { id: 'SEFCRI' }); map.addLayers([layerSEFCRI]); // Suba's edit dojo.connect(map, 'onLayersAddResult', function (results) { var toc = new agsjs.dijit.TOC({ map: map, layerInfos: [{ layer: layerSEFCRI, title: "SEFCRI", slider: true }] }, 'tocDiv'); toc.startup(); layerSEFCRI.setVisibleLayers([0]); mapReady(map); }); </script>
var map; var identifyTask, identifyParams; var urlSEFCRI = "http://myserver/ArcGIS/rest/services/biogeo/SEFCRI/MapServer"; var layerSEFCRI; require([ "agsjs/dijit/TOC", "dojo/_base/connect", "dojo/parser", "dojo/ready", "esri/map", "esri/InfoTemplate", "esri/arcgis/utils", "esri/dijit/InfoWindow", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function ( TOC, connect, parser, ready, Map, InfoTemplate, InfoWindow) { ready(function () { //parser.parse(); }); map = new Map("map", { basemap: "oceans", showAttribution: false, logo: false, //infoWindow: popup, center: [-80.2, 26.67], zoom: 11 }); map.resize(); loading = dojo.byId("loadingImg"); layerSEFCRI = new esri.layers.ArcGISDynamicMapServiceLayer(urlSEFCRI, { id: 'SEFCRI' }); map.addLayers([layerSEFCRI]); connect.connect(map, "onLayerAddResult", function (results) { var toc = new TOC({ map: map, layerInfos: [{ layer: layerSEFCRI, title: "SEFCRI", slider: true }] }, 'tocDiv'); toc.startup(); console.log("loaded"); layerSEFCRI.setVisibleLayers([0]); mapReady(map); });
