Does arcade support rounding of decimal numbers or applying a money format? Right now Arcade is spitting out 6.2568 for example but I only want to see 6.26
Hi Joerodney ,
In addition to the solution provided by Jeff Ward you can also use the Text function to format a value:
<SPAN class="token function">Text</SPAN><SPAN class="punctuation token">(</SPAN>$feature<SPAN class="punctuation token">.</SPAN>fieldname<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"$ #.00"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
What if you tried
"$" + Round($feature.fieldname, 2)
Mathematical Functions | ArcGIS for Developers
Perfect!
