We do our maps at 200 scale and we set all the point features 10 feet apart. So a tee with three valves would have all the valves 10' from the interesection.
We had Nobel Systems do our maps. Their product is second to none. For the blow-ups they created a second geodatabase for display of detail blow-ups that is not networked with the main lines. Also, our legend is on the first page of the atlas, so it gives us more room on the individual pages. Also, the parcels are colored according to the pressure zone.
Josh, Do you know of some information to help me learn to do the blow-ups?
Hi mtnbker1213, The Details are actually a feature dataset in the same geodatabase, and they are in a group layer in the data view, not the layout view. Their are significantly less features in the detail feature classes, basically just a point, line and polygon feature, but the symbolization is much more extensive so that it can symbolize each feature as any type of feature in the database.
As far as cartographic representations is INFO required for these? how well has that worked for you?
The blow up details you have are awesome to say the least. I understand that the tact you have used is to place the details in the Data View as a feature, so the dashed circle around a detail is a white polygon feature class with a dashed border set above the parcels and behind the various line/point features. The line and point features are a �??dummy�?� feature for visual purposes only, trimmed to length in the polygon and symbolized to match the �??real�?� water features. If I have that right then I applaud the creativity of merging some CAD philosophy with GIS. Keep up the good work.
