hi there,as the title said, i add two basemap layers instead of addarcgisbasemaps="true" in config.xml<layer label="TianDiTuWMTSMap" type="wmts" visible="true" alpha="1.0" style="default" servicemode="KVP" layerId="vec" tilematrixsetid="w" url="http://t0.tianditu.com/vec_w/wmts" /> <layer label="TianDiTuAnnotation" type="wmts" visible="true" alpha="1.0" style="default" servicemode="KVP" layerId="cva" tilematrixsetid="w" url="http://t0.tianditu.com/cva_w/wmts"/>
But the result is that they can display in Map view rather than OverViewMapWidget(its blank even without the red box), i read the Post Questions and Answers in forum,and make some mod in OverViewMapWidget.xml as below code:<?xml version="1.0"?> <configuration> <!-- possible values for initialstate: open or closed (default) --> <initialstate>closed</initialstate> <!-- by default it will use the same basemap as current main map, you can hardcode as below if you wish --> <layer type="wmts" mode="static" visible="true" url="http://t0.tianditu.com/vec_w/wmts"/> </configuration>
and in the OverViewMapComponent.mxml there isnot any code about WMTS so i add WMTS item as other type service: public function set configXML(value:XML):void { .............................................. case "osm": { var osmLayer:OpenStreetMapLayer = new OpenStreetMapLayer(); osmLayer.alpha = alpha; osmLayer.id = label; osmLayer.name = label; osmLayer.visible = visible; layerToAdd = osmLayer; break; } // added by Prac 20130809 To display WMTS map in OverviewMapWidget case "wmts": { var wmtsLayer:WMTSLayer =new WMTSLayer(); wmtsLayer.alpha = alpha; wmtsLayer.id = label; wmtsLayer.name = label; wmtsLayer.visible = visible; layerToAdd =wmtsLayer; break; } // added by Prac 20130809 To display WMTS map in OverviewMapWidget if (layerToAdd) { overviewMap.addLayer(layerToAdd); basemapLayerObjectToLayer[basemapLayerObject] = layerToAdd; } }after all these done it still doesnot work out, do you have any suggestion for this, thanks for your help.
