Hey Folks,
I am getting closer with my implementation of the Public Notification app. I was able to get the map working with my data, but I needed to add another Avery template (5389 - post cards). I was able to figure out the ReportLab tools to get everything on the page in the correct places with a logo and return address. The GenerateAveryLabels script tool works fine when I run it from ArcCatalog with some address data in the same format that the app will be passing - fields separated with a '~' and records separated with a '$'.
The CSV option works fine (I didn't touch that code), but I can't get any of the Avery labels to work. Even the built in labels quit working, the only error text I get is the "Data not available for this particular location" error. When I check the console I get this text in the results for the second GET call (the first GET call is the GP submitJob which succeeds):
{"jobId":"jb1002bd33a0941f1931714c5963c1211","jobStatus":"esriJobFailed",<BR />"messages":[{"type":"esriJobMessageTypeInformative","description":"Submitted."},<BR />{"type":"esriJobMessageTypeInformative","description":"Executing..."},<BR />{"type":"esriJobMessageTypeError","description":"Failed."}]}<BR /><BR /><BR />
Any thoughts?
Jeff
