I'm surprised that you are having difficulty changing this as you should be able to tell ArcPad whether the box should be checked or not via the default value.Check box controls should be used on text fields, as the values of True and False get recorded to the attribute table. The default value can be changed either via the control properties or by navigating the tree structure of the layer definition. I've included screenshots of both of these locations. You should type the words True and False in as shown here. Do not put them between double quotes, such as "True".After you've gone back and made sure that your axf looks like the screenshots I've provided are you still seeing that the check boxes are checked on by default?Thanks.
