Good morning,
We have followed the 'save back' solution that was presented. On further discussion with ESRI, they sent us some 'Good CAD Characteristics' (attached to this message) which are necessary for implementing ARCMap Indoors...in case that is the path you are headed.
It's not the heaviest of lifts, but the characteristics might stray from your entities CAD standards. We'll be revamping ours to dovetail into the Indoors product.
Hope this information helps as a supplement to the problem in the subject line.
Cheers,
Richard
This solved the issue for me as well. Saved the drawing to CAD 2010 and the linework appeared in ArcMap. Thanks for the great advice!
This solved the 'no geometry' issue. Saved the .dwg back to CAD 2000 version and .dwg appeared in ArcMap. Had to use the Georeferencing tool to correct its location, but it did get into the file. Thanks for the advice.
I had this issue also. Was using ArcMap 10.4.1 and the .dwg was saved as a 2010 AutoCAD document. I fixed the issue by saving the .dwg to 2007 format instead. I hope this helps someone else in the future.
I am having a similar problem. I have a CAD drawing from another company and I can see it fine in DWG TrueView 2010 program. But when I look at the file in ArcReader their seems to be nothing there..in table view or geogrpahy view. Any suggestions?
I've been having the exact problem. The AutoCad drawings I need to use show 0 features in all categories in ArcCatalog (identical to the posted thumbnails), and there is nothing visible in the preview, nor if I bring the drawing into ArcMap (ArcEditor level) - if I "zoom to layer" I get a blank screen.However, I did see the lines and other features in the previous poster's Glass.dwg with no trouble, and have been able to see a few other drawings in our network drive.Is there some sort of setting in AutoCad that allows/disallows a drawing to be visible if imported into a GIS? I am still working in 9.3.1. Thanks.
Hello, I have been working on adding CAD data into ArcGIS with no success, it just did not show anything.In the dwg file layer property when examine using ArcCatalog,all the values from coordinates tab and details tab showed as zeros. I think this might be the problem, anyone knows how to solve it?Everything seems working fine in AutoCAD. And I did save the dwg file as older version like AutoCAD 2000, or R14, but still failed display in ArcMAP.Please help, thanks.Joanie
