Im having exact same problems. Di somebody figure this out??
Thanks!
Luke, a few questions related to the GetBufferLock error:1) Have you verified with the Eclipse debugger that your app crashes as soon as you "step into" zoomToResolution()?2) And, that happens 100% of the time?3) Can you copy the entire crash sequence from Logcat and either paste or attach it?4) What's the make/model of the device?5) Android OS version?6) ArcGIS SDK version?7) Code snippet of the method where the error is happening?Thanks,-Andy
are you using the correct map units? I tried setting my scale to 1200 (1":100ft) and it worked. When you call the CenterAt() method, try setting the animation property to false, see if that solves your problem. map.CenterAt(point,false);As Andy points out in the thread below, perhaps the pan animation from CenterAt() is not completing before you are setting the scale, thus nothing is happening.see this thread:http://forums.arcgis.com/threads/51928-Callout-doesn-t-move-with-MapView.centerAt?highlight=animation
map.setOnSingleTapListener(new OnSingleTapListener() { /** * */ private static final long serialVersionUID = 1L; @Override public void onSingleTap(float x, float y) { double _x = x; double _y = y; double scale = 500000; Point pt = new Point(_x,_y); map.centerAt(pt,true); map.setScale(scale); } });
I tried both MapView zoomToScale and zoomToResolution. In zoomToScale I tried 24000 as the scale parameter. In zoomToResolution, I tried .5, which is the highest resolution of my data. Am I misinterpreting these parameters, The only thing that it does is pan the map to center it around the point. No zooming occurs. I want to be able to zoom to the point and zoom to the highest res of the data in the mapview.
