For example: suppose the polygon area is 10,000 square meters, its perimeter is 500 meters, and the buffer radius is 1 meter. Then the (externally) buffered polygon area is estimated as[INDENT]10,000 + 500 * 1 [+ Pi * 1^2]= 10,500 [or 10,503.14] square meters.[/INDENT]
Is there a way to estimate the area of a buffer polygon if you know the buffer distance and the area of the original polygon?
You can do it all in one step, Lorna. I wrote about focusing on just the problem lakes because they are problems! But if buffering them succeeds, then you should be able to buffer all the lakes by computing their mutual complement (one operation) and buffering it (one operation).
Creating the complement of the lakes is a really interesting idea, but I have such a huge number of lakes to do this for that I don't think it is feasible.
As part of a process further down the line I need to re-buffer my buffers to get a more accurate reading of lake area and to help with creating pour points for catchment delineation. This second buffer process is giving me errors as well.
Thanks everyone, still looking for ideas 🙂
# Description # ----------- # This creates an area of interest feature class, a few buffers of the area of interest, and a fishnet polygon to use for tile-by-tile psudo-parallel processing. # Written for Python version: 2.5.1 (PythonWin) # Written for ArcGIS version: 9.3.1 (should be forward compatible). # Author: Chris Snyder, WA Department of Natural Resources, chris.snyder(at)wadnr.gov # Date created: # Last Updated: 20090923, csny490 try: #Import system modules and creates the Geoprocessor object (the v9.2 way) import sys, string, os, glob, shutil, time, traceback, arcgisscripting gp = arcgisscripting.create(9.3) #Defines some functions def showGpMessage(): try: print >> open(logFile, 'a'), "\n" + gp.GetMessages() + "\n" print "\n" + gp.GetMessages() + "\n" except: pass def showPyMessage(): try: print >> open(logFile, 'a'), str(time.ctime()) + " - " + str(message) print str(time.ctime()) + " - " + str(message) except: pass #Sets a date/time stamp variable in the format yyyymmddhhmmss (example: 20060330132345) dateTimeStamp = time.strftime('%Y%m%d%H%M%S') #Specifies the root variable, makes the logFile variable, and does some error checking... root = sys.argv[1] if os.path.exists(root)== False: print "Specified root directory: " + root + " does not exist... Bailing out!" sys.exit() scriptName = sys.argv[0].split("\\")[len(sys.argv[0].split("\\")) - 1][0:-3] #Gets the name of the script without the .py extension logFile = root + "\\log_files\\" + scriptName + "_" + dateTimeStamp[:8] + ".log" #Creates the logFile variable if os.path.exists(root + "\\log_files") == False: os.mkdir(root + "\\log_files") if os.path.exists(logFile)== True: os.remove(logFile) message = "Deleting log file with the same name and datestamp... Recreating " + logFile; showPyMessage() workspaceDir = "overlay_index" if os.path.exists(root + "\\" + workspaceDir)== False: message = "Creating layer directory: " + root + "\\" + workspaceDir; showPyMessage() os.mkdir(root + "\\" + workspaceDir) #Attempts to check out the highest grade license available... if gp.CheckProduct("ArcInfo") == "Available": gp.SetProduct("ArcInfo") elif gp.CheckProduct("ArcEditor") == "Available": gp.SetProduct("ArcEditor") elif gp.CheckProduct("ArcView") == "Available": gp.SetProduct("ArcView") else: messsage = "No ArcGis licesnses are available... Exiting script!"; showPyMessage(); sys.exit() message = "Selected an " + gp.ProductInfo() + " license"; showPyMessage() #Sets some environment variables gp.overwriteoutput = True gp.loghistory = False sr = 'PROJCS["NAD_1983_HARN_StatePlane_Washington_South_FIPS_4602_Feet",GEOGCS["GCS_North_American_1983_HARN",DATUM["D_North_American_1983_HARN",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1640416.666666667],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-120.5],PARAMETER["Standard_Parallel_1",45.83333333333334],PARAMETER["Standard_Parallel_2",47.33333333333334],PARAMETER["Latitude_Of_Origin",45.33333333333334],UNIT["Foot_US",0.3048006096012192]]' gp.OutputCoordinateSystem = sr gp.XYTolerance = "0.001 METERS" gp.XYResolution = "0.0005 METERS" gp.workspace = root + "\\" + workspaceDir #Process: Creates a FGDB to hold all the spatial layers fgdbName = "overlay_index" fgdbPath = gp.workspace + "\\" + fgdbName + ".gdb" gp.CreateFileGDB_management(gp.workspace, fgdbName); showGpMessage() #Process: Makes a FC of the PLS polys we want plsFC = root + "\\gis_layers\\pls.gdb\\pls" plsFL = "pls_feature_layer" gp.MakeFeatureLayer_management(plsFC, plsFL, "SUR_OWN_CD > 0 OR TIM_OWN_CD > 0", "", ""); showGpMessage() dnrMgmtAllFC = fgdbPath + "\\dnr_mgmt_all" gp.Dissolve_management(plsFL, dnrMgmtAllFC, "", "", "SINGLE_PART"); showGpMessage() #Process: Creates a fishnet layer (the basis of the index polygons) fishnetLine1FC = fgdbPath + "\\fishnet_line1" dsc = gp.describe(dnrMgmtAllFC) xMin = dsc.extent.xmin yMin = dsc.extent.ymin xMax = dsc.extent.xmax yMax = dsc.extent.ymax bufferWidth = 1 #Buffer width expands the the extent of the fishnet by that many map units (to make sure it extends past DNR lands a bit) numberOfRows = 6 numberOfColumns = 6 gp.CreateFishnet_management(fishnetLine1FC, str(xMin - bufferWidth) + " " + str(yMin - bufferWidth), str(xMin - bufferWidth) + " " + str(yMin), "0", "0", numberOfRows, numberOfColumns, str(xMax + bufferWidth) + " " + str(yMax + bufferWidth), "NO_LABELS", ""); showGpMessage() fishnet1FC = fgdbPath + "\\fishnet_poly1" gp.FeatureToPolygon_management(fishnetLine1FC, fishnet1FC, "", "", ""); showGpMessage() gp.Delete_management(fishnetLine1FC, ""); showGpMessage() #Process: Creates a 2nd fishnet layer (that is more dense than the original) fishnetLine2FC = fgdbPath + "\\fishnet_line2" densificationFactor = 12 #this densification factor ABSOLUTELY NEEDS to be a multiple of 2 (e.g. 2,4,6,8,etc) gp.CreateFishnet_management(fishnetLine2FC, str(xMin - bufferWidth) + " " + str(yMin - bufferWidth), str(xMin - bufferWidth) + " " + str(yMin), "0", "0", str(numberOfRows * densificationFactor), str(numberOfColumns * densificationFactor), str(xMax + bufferWidth) + " " + str(yMax + bufferWidth), "NO_LABELS", ""); showGpMessage() fishnet2FC = fgdbPath + "\\fishnet_poly2" gp.FeatureToPolygon_management(fishnetLine2FC, fishnet2FC, "", "", ""); showGpMessage() gp.Delete_management(fishnetLine2FC, ""); showGpMessage() #Process: Updates fishnet1FC with fishnet2FC for specified areas hcpUnitFC = root + "\\gis_layers\\hcpunit.gdb\\hcpunit" oesfFC = fgdbPath + "\\oesf" gp.Select_analysis(hcpUnitFC, oesfFC, "HCPUNIT_ID = 1", "", ""); showGpMessage() fishnet1FL = "fishnet_1_feature_layer" gp.MakeFeatureLayer_management(fishnet1FC, fishnet1FL, "", "", ""); showGpMessage() gp.SelectLayerByLocation_management(fishnet1FL, "INTERSECT", oesfFC, "", "NEW_SELECTION"); showGpMessage() fishnet2FL = "fishnet_2_feature_layer" gp.MakeFeatureLayer_management(fishnet2FC, fishnet2FL, "", "", ""); showGpMessage() gp.SelectLayerByLocation_management(fishnet2FL, "HAVE_THEIR_CENTER_IN", fishnet1FL, "", "NEW_SELECTION"); showGpMessage() gp.Delete_management(oesfFC, ""); showGpMessage() fishnetFC = fgdbPath + "\\fishnet_poly" gp.Update_analysis(fishnet1FC, fishnet2FL, fishnetFC, "BORDERS", ""); showGpMessage() #Process: Make a line FC version of fishnetFC fishnetLineFC = fgdbPath + "\\fishnet_lines" gp.FeatureToLine_management(fishnetFC, fishnetLineFC, "", "NO_ATTRIBUTES"); showGpMessage() #Process: Unions everything together union1FC = fgdbPath + "\\union1" gp.Union_analysis(fishnetFC + ";" + dnrMgmtAllFC, union1FC, "ONLY_FID", "", "GAPS"); showGpMessage() #BLAH BLAH BLAH - I had to trim this part out to post it to the forum (stupid 10,000 charater limit!!!) #Process: Compacts the PGDB gp.Compact_management(fgdbPath); showGpMessage() #Process: Creates a .txt file that indicates to other scripts how many tiles there are (this is used so that the run_union_master script doesn't have to use the gp and waste memory) print >> open(root + "\\log_files\\" + "therearethismanytiles_" + str(numberOfTiles) + ".txt", 'a'), "therearethismanytiles_" + str(numberOfTiles) message = "ALL DONE!"; showPyMessage() print >> open(root + "\\log_files\\" + scriptName + "_isalldone.txt", 'a'), scriptName + "_isalldone.txt" except: print >> open(root + "\\log_files\\" + scriptName + "_bombed.txt", 'a'), scriptName + "_bombed.txt" message = "\n*** LAST GEOPROCESSOR MESSAGE (may not be source of the error)***"; showPyMessage() showGpMessage() message = "\n*** PYTHON ERRORS *** "; showPyMessage() message = "Python Traceback Info: " + traceback.format_tb(sys.exc_info()[2])[0]; showPyMessage() message = "Python Error Info: " + str(sys.exc_type)+ ": " + str(sys.exc_value) + "\n"; showPyMessage() message = "\n*** PYTHON LOCAL VARIABLE LIST ***"; showPyMessage() variableCounter = 0 while variableCounter < len(locals()): message = str(list(locals())[variableCounter]) + " = " + str(locals()[list(locals())[variableCounter]]); showPyMessage() variableCounter = variableCounter + 1 showPyMessage()
