ESRI answer using Pro: First off, you are right there is no location scale on a 3d virtual world, there is only a camera distance and distance from observer. You can however still replicate the same scenario in 3d by tilting your camera view straight from top down view, completely directly above then controlling the distance from the observer point on the left corner of the map task bar you can specify the distance from your view and adjust the height. You could also type in the height value looking top down view at 90 degrees. Scale in 2D is not the same as Scale in 3D but there are ways to share a specific location for consistency and precision.
