is there a method in ArcGIS Runtime SDK for iOS to get bundle version?
Not out of the box, but there is this Swift extension we published as part of the data-collection-ios Open Source app:
https://github.com/Esri/data-collection-ios/blob/1b846d7c8f19d994a83fae259ec2cceeef19be2f/data-collection/data-collection/Extensions/Foundation/Bundle%2BVersion.swift#L18-L45
extension Bundle <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">static</SPAN> <SPAN class="keyword token">let</SPAN> agsBundle <SPAN class="operator token">=</SPAN> <SPAN class="token function">AGSBundle</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">/// An end-user printable string representation of the ArcGIS Bundle version shipped with the app.</SPAN> <SPAN class="comment token">///</SPAN> <SPAN class="comment token">/// For example, "2000"</SPAN> <SPAN class="keyword token">static</SPAN> <SPAN class="keyword token">var</SPAN> sdkBundleVersion<SPAN class="punctuation token">:</SPAN> String <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>agsBundle<SPAN class="operator token">?</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">object</SPAN><SPAN class="punctuation token">(</SPAN>forInfoDictionaryKey<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"CFBundleVersion"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN><SPAN class="operator token">?</SPAN> String<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">?</SPAN><SPAN class="operator token">?</SPAN> <SPAN class="string token">"?"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="comment token">/// An end-user printable string representation of the ArcGIS Runtime SDK version shipped with the app.</SPAN> <SPAN class="comment token">///</SPAN> <SPAN class="comment token">/// For example, "100.0.0"</SPAN> <SPAN class="keyword token">static</SPAN> <SPAN class="keyword token">var</SPAN> sdkVersion<SPAN class="punctuation token">:</SPAN> String <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>agsBundle<SPAN class="operator token">?</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">object</SPAN><SPAN class="punctuation token">(</SPAN>forInfoDictionaryKey<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"CFBundleShortVersionString"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN><SPAN class="operator token">?</SPAN> String<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">?</SPAN><SPAN class="operator token">?</SPAN> <SPAN class="string token">"?"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="comment token">/// Builds an end-user printable string representation of the ArcGIS Bundle shipped with the app.</SPAN> <SPAN class="comment token">///</SPAN> <SPAN class="comment token">/// For example, "ArcGIS Runtime SDK 100.0.0 (2000)"</SPAN> <SPAN class="keyword token">static</SPAN> <SPAN class="keyword token">var</SPAN> ArcGISSDKVersionString<SPAN class="punctuation token">:</SPAN> String <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="token function">String</SPAN><SPAN class="punctuation token">(</SPAN>format<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ArcGIS Runtime SDK %@ (%@)"</SPAN><SPAN class="punctuation token">,</SPAN> sdkVersion<SPAN class="punctuation token">,</SPAN> sdkBundleVersion<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
perfect, thank you very much!
