The layer for the bing base maps appears in the contents window and yet the screen is blank. This is only occurring on one machine.Internet connection is fine. Opened the application one day to see everylayer in map was broken and then the base map vanished when fixed.What gives?
I have the same problem. None of the stock basemaps render when selected. I get error message "The basemap contains one or more invalid layers." I uninstalled and reinstalled, checked firewall, nothing works.
Do any of the other functions which use ESRI services work? e.g. Find, Directions, etc? If not then it is likely to be a connectivity issue between your PC and the ESRI server. In most cases this is a proxy server or corporate firewall configuration issue.If it's just the basemaps which are not working - you should also try clearing the cache.RegardsMike
It appears AGX stores session info in the user's windows profile area. Try clearing out all the AGX related info in the user profile. I fixed lost symbols and other weird behavior by deleting the profile information. I figured this out after reinstalling which did not help.
