Hello,I have a script that is to geocode addresses from a database, intersect the results with three boundary files and do a tabletotable conversion on the results. Below is the intersect statement I am using.
arcpy.Intersect_analysis([geocode_results, boundary1_shp, boundary2_shp, boundary3_shp], qResults, "ALL", "", "INPUT")
The statement is failing on qResults (e.g. creating the output of the intersect). It seams that no matter what I put there (file path or variable name), the compiler is appending ".shp.shp" to the file name which causes an invalid file error. ERROR 000210: Cannot create output \\mydrive\ArcGIS\Default.gdb\qResults.shp.shpERROR 000354: The name contains invalid charactersFailed to execute (Intersect).Any help, would be greatly appreciated.Thanks,Dan
