Trying to change the Illinois state plane projection in the local government model to represent the correct projection for our city. Seem like it should be rather straight forward but having a surprising amount of difficulty, thanks.
why don't you set the coordinate system of the data frame to match it? or do you have a mismash of data in different coordinate system? Normally the first file that you add to a dataframe, sets the coordinate system you want, then you can add other data. Alternately, rightclick on the data frame, select properties, then define it
These are the steps that I took when I converted my data to the LGIM:
All of this is done in ArcCatalog
Once you have this, you have a blank local government schema gdb and you can import your data in to it. If you need help with this, go here.
Good luck
Perfect, thanks for the help
I am running ArcGIS 10.5.1 I have tried this workflow at least 7 times and it is not working for me. try1 is an empty gdb. Importing the xml to gdb works if you do not change the spatial reference. Changing the spatial reference as instructed consistently causes issues for me. Any thoughts?
