This is an isolated problem with some organization accounts. Please call tech support and give them your subscription ID and we will fix the problem. Or alternatively, post your subscription ID here.Sorry for the inconvenience,Mike
Mike,
My ID si: 8554167900
I have the same problem: "Invalid tenant Id. Unable to find tenant in database. Invalid tenant login."
Guillermo,
This should be fixed now. Let us know if you have any problems.
Mike
Thanks Mike! Now we can upload feature services in the organization.
I need one more thing. We are Esri Silver Partner and we administrate this
510 users organization.
The want to use the corporative login but it doesn´t work with Salesforce
SAML login (identity provider) that is approved by ArcGIS Online.
When we use the metada generated in ArcGISOnline in Salesforce (URL ACS -
Acertion Customer Service), that produce an error when we want to login in
ArcGIsOnline:
Invalid_SAMLResponse error_description=Unable to login using Idp Unable to
validate SAML response
We are not sure if the configuration is correct or not, you have
configuration details for Active Directory and OpenAM but what about others?
Our project is in danger for this security issue.
Thanks in advance for your feedback!
Greatings from Argentina.
Guillermo.-
Guillermo Ciampagna
Director general
Pje. Santo Tomás 341, X5000LAA
Ciudad de Córdoba, Argentina.Tel/fax: 00-54-351-4259096
Móvil: 00-54-351-5-600582
Skype: gciampagna
*guillermo.ciampagna@ciampagna.com.ar
<guillermo.ciampagna@ciampagna.com.ar>*
www.ciampagna.com.ar <http://www.ciampagna.com.ar>
2014-10-03 12:24 GMT-03:00 Mike Minami <geonet@esri.com>:
GeoNet<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo8h7SGfRSMkw-2FpvHGF9-2FW3rK-2Bvs1kL9-2FnG6jjf2NZhrLDz0M-2BrY-2By9IaziQEKVk3Hg-3D-3D_OFuVmkqlPUFejGZHEiAZh-2BwILr1HpGwmdrr1CIh1jm7Bu8JytTSHXy937UHDKVyTk3g7EbG-2B1mZDs2EJgU8Wv-2BI59GgW-2BiULCoRv4h-2BGF4Fv4wSGgpdtlKRbMLvSN7o550SsRRIzfSXhKGQ-2FA8ecu7Cc9k6EekI5xDCcpsZ-2F7HWN-2BJV0lv4PWjEEIjUR-2B5-2FvK9tZQtTiUiG5m-2BVjNw-2FtflKByD-2BsHn-2BV6ZOMqqUlwIpQyJeN5BTGrvmHaV7NG8tGNd5adwa41ewXZ6PvTg8wUXTtOXX1gb6xZCPW-2F9OsSLW9OJ5gDp3JUsb3lpbRNkzKB57UW3LQHxNTnovKfC0GCQ-3D-3D> Issuewith publishing a Feature Servicereply from Mike Minami<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo7A4BXwO9PY1WvQ5cXCtK4-2BSzaYAWbep1g7MeWcxXKCxYil2QP2ixsUiesw0zHBPVPx3wXvP76-2FW8JxYmmawimE-3D_OFuVmkqlPUFejGZHEiAZh-2BwILr1HpGwmdrr1CIh1jm7Bu8JytTSHXy937UHDKVyTk3g7EbG-2B1mZDs2EJgU8Wv-2BI59GgW-2BiULCoRv4h-2BGF4Fv4wSGgpdtlKRbMLvSN7o550SsRRIzfSXhKGQ-2FA8ecu-2Bdo9cywK1IL6o4bpeKC4S3hNSZBSVoYd0oesIASh4anyQ0YGAT7mtvkGKl4JMv-2Bao4Alt1-2BvfVySkSfpmYcOMUqPlpFc2Cd-2BvyGKBiL3zh3AdzCZV57mJp6gKRadoUT13RnXDTQ8yO7zPjMkhUvplYVsD6mmSPGGjZdjamMwsLs0R2FDbNyIubec2ui78BGQg-3D-3D>in ArcGIS Online - View the full discussion<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo0VQjeJBYpG9HGC8QZBT-2FEw5MnIAPP2CxYnSmG7P20QVcB54c8KsvRmcHZ-2BjEnbrBxRV-2BCWtiY11vwPIt22FNF0-3D_OFuVmkqlPUFejGZHEiAZh-2BwILr1HpGwmdrr1CIh1jm7Bu8JytTSHXy937UHDKVyTk3g7EbG-2B1mZDs2EJgU8Wv-2BI59GgW-2BiULCoRv4h-2BGF4Fv4wSGgpdtlKRbMLvSN7o550SsRRIzfSXhKGQ-2FA8ecu80AO56LDV2wjlYQfgJAlraloJz6WuQo-2F7Q11431KPTdTRaesnhjmBj7FtuUcCXosddU6U98Z0Ddve4nHvU3CQi2FfLEhuxqNlHFy0LARnDID0Ov450VuHtstW3IXKW3k2m2Z0wAFc7JkmZfawVM-2F7MGU7Pp2KOU3hEh3bOHf0Taih0rUIkmhbrIB5F2AdyzVg-3D-3D>
GeoNet
I'm having the save problem.My ID is 3619726171
