What is required to install and run Web AppBuilder Online? Do I need 10.3? Do I need a subscription other then a ArcGIS account/Profile?
All and any information is greatly appreciated!
Joe C.
I have downloaded the ZIP file but I have not yet installed it until I know what is required.
Thanks for your time!
Joseph, Web AppBuilder Online can be used totally online without downloading, but you do need an account.
If you downloaded Web Appbuilder 1.1 for Developers (WAB), that can be modified locally and hosted thru you web server. At a minimum, you still need an ArcGIS Online account to register the WAB install. For my tips Tips and Observations for getting Web AppBuilder - Developer Edition Installed and when you get into it more Web AppBuilder Developer Edition – Customization Resource List
Do you know whether you plan to do it 100% online or host is local? You can sign-up for a free developer account on ArcGIS Online, but I think it may have limitations when it comes to hosting online. I have an enterprise ArcGIs Onine account, so I don't have alot of experience with the other right now.
...oh, and no, you do not need 10.3 or any ArcGIS Desktop for that matter.....
I just registered WAB by following these steps.
After logging into my ArcGIS online account and “add item”. I do not get the register portion...could my computer name be incorrect to cause this? Any ideas?
[cid:image004.jpg@01D08194.27DC8250]
Cheers,
Joe Cartier
GIS CAD Technician
Engineering - Infrastructure & Geomatics
Telephone: 519-255-6257 EXT. 6322
E-mail: jocartier@city.windsor.on.ca<mailto:jocartier@city.windsor.on.ca>
Hi Joseph,
Did you enter your actual local computer name for "<myServerName>"
this should be the machine you plan to do the work on, and not an ArcGIS Server or anything. You attached graphic showed it as a blank, and I'm not sure if you whited it out for the graphic or if it was an invalid name.
I mentioned that for me it took a typo and did create the app, but then when I edited, I did correct the typo.
One other thing, are you the administer on your AGOL account? I haven't tested to see if a AGOL user can be restricted from registering a computer, but that might be one of the options in the Admin tools. If you are the administrator, that wouldn't be the issue.
If this doesn't work, let me know more about the computer name you used (do need actual name, but sample if any special character). I would like to update my instructions if there is more that I could include to make it clearer. Thanks
EDIT: ....oh, and importent step....make sure you selected the radio button for "Application". That may be why it looks different.
After running the batch file the Web AppBuilder gets opened in a browser window, if you look at the address bar your machine name is in it. I just used that first bit of the address to fill out the registration info on ArcGIS Online.
