http://blahserver/Apps/test&Extent=xMin,yMin,xMax,yMax
My project
http://infopublic.pravstat.kz:8399/crime-map/
Would this same technique work in a custom javascript api application?
I tried this technique but the application still zooms to the default extents of a county if I type in coordinates at the end of the url that are in a zoomed-in area of the county. Is there any special coding needed to obtain this functionality in the javascript api?
I stumbled across a blog that discuss using xy minmax values as url parameters. First, is this possible with Silverlight? If so, can someone shove me in the right direction. I assume the url would look something like this http://blahserver/Apps/test&Extent=xMin,yMin,xMax,yMaxThanks,Brett
http://blahserver/Apps/test/index.htm?Extent=xMin,yMin,xMax,yMax
