Is anyone else having problems with a Receive Text from TCP socket and GeoEvent definitions in 10.3?
I have a lightning feed that I have to establish a connection with as a client, so I have to modify the input a bit, BUT...
This has worked for me in 10.2.1 and 10.2.2, but now with 10.3, everything has stopped.
I narrowed it down to pre-defining the geoevent definition. If I format any of the fields as "Double" or "Integer", the input will not receive the feed.
Is anyone else seeing anything like this? Since this is not a clean install, maybe I need to delete everything in the GeoEvent folder sturcture and reinstall?
Thank you,
--Adam
