I can add an ArcGISImageServiceLayer with a different spatialReference than the initially set extent and other layers in the map such as the one from ESRI (http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer). When I try to use the same Imageserver layer as a new.dijit.BasemapLayer it does not reproject correctly as when adding it by just using the usual map.addLayer function.I have tried it two different versions of this but neither works.Version #1var NAIP2009params = new esri.layers.ImageServiceParameters(); NAIP2009params.noData = 0; var islNAIP2009 = new esri.layers.ArcGISImageServiceLayer("http://gisservice.mt.gov/ArcGIS/rest/services/MSDI_Framework/NAIP_2009/ImageServer", { imageServiceParameters: NAIP2009params }); var basemapNAIP2009 = new esri.dijit.Basemap({ layers: [islNAIP2009], id: "bmNAIP2009", title: "NAIP 2009" }); basemaps.push(basemapNAIP2009);Version #2 var basemapNAIP2009 = new esri.dijit.Basemap({ layers: [new esri.dijit.BasemapLayer({ url: "http://gisservice.mt.gov/ArcGIS/rest/services/MSDI_Framework/NAIP_2009/ImageServer" })], id: "bmNAIP2009", title: "NAIP 2009" }); basemaps.push(basemapNAIP2009);Any help or existing example is much appreciated.
