Hi Tom,I randomly receive this error in a little grey box with an ok button: Error during print! An error occurs during print I click on OK and it just returns me to the web app.When I look in the arcgisoutput folder the mxd and the pdf are there and they have all of the elements. Any ideas?I am using the PCHarcgisSOE.jar dated 2/1/2012, the pchprintwidget dated 1/31/2012, Flexviewer 2.5, AGS Api 2.5 dated 11/30/2011, ArcGIS Server 10, ArcGIS Desktop 10 Service Pack 3, and Java version 1.6.0_16On a side note, where do you change the selection for the type of North Arrow used in the map?This is an awesome tool and I cant wait for our staff to be able to use it!Thank you!Luci
I have it working, but sometimes get the error. I am still testing it, but it seems to happen when I have a layer or layers with a transparency that I set in the flexviewer config.xml file. Sometimes the legend shows the symbology properly and sometimes it looks odd. I definitely get the error every time I have more items in my legend than can be displayed on the layout. I have not figured out how to set the legend not to exceed the size of the layout.Luci
private function printResult(searchResult:Object):void { if (currentState=="stateSelectExtent") btnPrint2.enabled=true; else btnPrint.enabled=true; var resultString:String=searchResult.toString(); trace("resultString: "+resultString); if(resultString.indexOf("<html>")>-1) { Alert.show(resultString, "Error during print!"); } else { var obj:Object=com.esri.ags.utils.JSON.decode(searchResult.toString()); trace("obj.outputFile: "+obj.outputFile); if(obj.outputFile) { //todo: preparations for ArcGIS 10.1 if(obj.outputFile.indexOf("/rest/directories")==0) { obj.outputFile = "http://localhost:6080/arcgis"+obj.outputFile; } trace("obj.outputFile: "+obj.outputFile); navigateToURL(new URLRequest(obj.outputFile)); } else { Alert.show(searchResult.toString(), "Error during print!"); } } }
