# classic example of mutabilty in action a = ['spam', 'eggs', 100, 1234] b = a b.append("abc") print a # ['spam','eggs',100,1234,'abc'] # << note that a is altered when we only appended to b print b # ['spam','eggs',100,1234,'abc']
import arcpy infc = "C:/Pipeline" # Identify the geometry field # desc = arcpy.Describe(infc) shapefieldname = desc.ShapeFieldName # Create search cursor # rows = arcpy.SearchCursor(infc) featureList=[] array = arcpy.Array() point = arcpy.Point() # Build polyline list # for row in rows: feat = row.getValue(shapefieldname) partnum = 0 partcount = feat.partCount while partnum < partcount: part = feat.getPart(partnum) pnt = part.next() pntcount = 0 pntArray = arcpy.Array() while pnt: if pnt: point = arcpy.Point() point.X = pnt.X point.Y = pnt.Y point.ID = pnt.ID point.Z = pnt.Z point.M = pnt.M #Create an array of points representing a line pntArray.add(point) pnt = part.next() pntcount += 1 if not pnt: pnt = part.next() partnum += 1 #Create a master array of point arrays in order to sort them array.add(pntArray) # Sort polyline array # pLineMax = array.count dummyPoint = arcpy.Point() dummyArray = arcpy.Array() #Index for point arrays that needs comparison pLineIndex = 0 while pLineIndex < pLineMax - 1: #Index for point arrays that is a test comparison pLineIndex2 = pLineIndex + 2 while pLineIndex2 < pLineMax - 1: # Compare endpoint of line to endpoints of other lines tempPoint1 = array[pLineIndex].getObject(array[pLineIndex].count-1) tempPoint2 = array[pLineIndex2].getObject(0) tempPoint3 = array[pLineIndex2].getObject(array[pLineIndex2].count-1) # if endpoint matches another segment if str(tempPoint1) == str(tempPoint2): # Assign pointer to point array that needs to be moved pntArray = array.getObject(pLineIndex2) # Remove point array from master array array.remove(pLineIndex2) # Insert point array in the appropriate place array.insert(pLineIndex + 1, pntArray) # Exit the while loop pLineIndex2 = pLineMax pLineIndex2 += 1 pLineIndex +=1
