In ArcGIS Online kan ik functies niet koppelen op basis van de kolommen lat (niet Latitude) en latitude. Hoe doe ik dit?
It's possible to do, but not with the BAT - Battery layer as it's currently not working as expected. It looks like none of the Analysis tools will work on it in it's current state.
Carmel
Hi Branco,
Are you able to share the layer URLs with us?
What kind of data is BAT - Battery? Is it a hosted feature service or did was it a CSV you dragged and dropped on the map?
https://services.arcgis.com/BKDj2O9wOxDS007e/arcgis/rest/services/libelium_service/FeatureServer/1 It is data that I receive from some sensors, which are sending data to my esri account.
Hi Branko,
Thanks for that - I've ran the analysis and encountered the same error.
I've noticed that none of the BAT - Battery features appear on the map, and same with any of the libelium_services layers. How was this created? Do you see the features on the map? There may be a geometry issue.
Additionally, when I query the rest end point of the layers (Where = '1=1'), this is what I am returned which I haven't seen before:
Hi Carmel,Thanks for replies, I am aware of that problem, I have asked Libelium (who makes sensors and made solution to send data from sensors to esri cloud) in Geometry property missing at ESRI data - www.libelium.com/forum and thay are aware of that too. But when I get geometry position I will still have to join those layers to show them on one layer.I have managed to get last row from data of layer by using ArcGIS API, but it is demanded now to do this in ArcGIS Online account.Branko
