Hi James,i don't know how to thank yuo.without your help I would not have ever made.I write the correct code for all who need it.thanks, thanks, thanksBarbara
If Not cboStrada.SelectedText = "" Then ' Or try cboStrada.SelectedValue strQuery = "Nome_Strada = '" & cboStrada.Text & "'" ElseIf Not cboCodice.SelectedText = "" Then strQuery = "Codice = '" & cboCodice.Text & "'" ElseIf Not cboProvincia.SelectedText = "" Then strQuery = "Provincia = '" & cboProvincia.Text & "'" Else MsgBox ("No values set in any of the ComboBoxes!") End If
hello,I better explain what it will do.Attached are two photos that you show what can I do now.I would however be able to do a search that lets you select any value ofany combobox and not just one.I would add these other queries:strQuery = "Nome_Strada= '" & cboStrada.Text & "' and Codice = '" & cboCodice.Text & "'and Provincia = '" & cboProvincia.Text & "'" orstrQuery = "Nome_Strada= '" & cboStrada.Text & "' or Codice = '" & cboCodice.Text & "'and Provincia = '" & cboProvincia.Text & "'"I tried with if then else cycles but the result is always and only, the first choice in the cycle if.Sorry if I was not too clear.Thanks.
If Not cboStrada.Text = "" Then strQuery = "Nome_Strada = '" & cboStrada.Text & "'" ElseIf Not cboCodice.Text = "" Then strQuery = "Codice = '" & cboCodice.Text & "'" ElseIf Not cboProvincia.Text = "" Then strQuery = "Provincia = '" & cboProvincia.Text & "'" Else msgBox("No values set in any of the ComboBoxes!") End If
