I need to create buffer
In the output buffer in the attribute table has a record for each polygon
but my result is a single record for every polygon
as I can get the result I need "record for each polygon"
then to calculate the area of each polygon
in your buffer tool box, set the Dissolve to "None" and each feature will have an individual buffer
Hello Jorge Orellana
I'll explain what I want to do with the buffer
I have a POI Shaperfile 4500 with record
the problem is that there are points that were geocoded twice
then:
I thought to make a buffer, with the option of "all" to generate a single polygon me those points that are in a perimeter of 25 meters
to bequeath to select areas with higher polygons
