I have an issue where using the Editor + TemplatePicker causes the feature layer's (that is not editable) pop up template to not display or only briefly when using this code:
featureLayer.on("click", function(evt) {
var center = evt.graphic.geometry;
map.infoWindow.setFeatures([evt.graphic]);
map.infoWindow.show(center);
});Also I have a problem where the label layer's labels are editable, I managed to disable this by adding the code below. I don't know if there's a better way.
labelLayer.disableMouseEvents();
The full code I inserted in this sandbox after settings variable:
//create a feature collection for the flickr photos
var featureCollection = {
"layerDefinition": null,
"featureSet": {
"features": [],
"geometryType": "esriGeometryPoint"
featureCollection.layerDefinition = {
"geometryType": "esriGeometryPoint",
"objectIdField": "ObjectID",
"drawingInfo": {
"renderer": {
"type": "simple",
"symbol": {
"type": "esriPMS",
"url": "images/flickr.png",
"contentType": "image/png",
"width": 15,
"height": 15
"fields": [{
"name": "ObjectID",
"alias": "ObjectID",
"type": "esriFieldTypeOID"
"name": "description",
"alias": "Description",
"type": "esriFieldTypeString"
"name": "title",
"alias": "Title",
//define a popup template
var popupTemplate = new PopupTemplate({
title: "{title}",
description: "{description}"
//create a feature layer based on the feature collection
featureLayer = new FeatureLayer(featureCollection, {
infoTemplate: popupTemplate
map.addLayer(featureLayer);
var symbol = new esri.symbol.TextSymbol();
var renderer = new esri.renderer.SimpleRenderer(symbol);
var labelLayer = new esri.layers.LabelLayer();
labelLayer.addFeatureLayer(featureLayer, renderer, "${CITY_NAME}");
map.addLayer(labelLayer);
requestPhotos();
function requestPhotos() {
//get geotagged photos from flickr
//tags=flower&tagmode=all
var requestHandle = esriRequest({
url: "http://api.flickr.com/services/feeds/geo?&format=json",
callbackParamName: "jsoncallback"
requestHandle.then(requestSucceeded, requestFailed);
function requestSucceeded(response, io) {
//loop through the items and add to the feature layer
var features = [];
arrayUtils.forEach(response.items, function(item) {
var attr = {};
attr["description"] = item.description;
attr["title"] = item.title ? item.title : "Flickr Photo";
var geometry = new Point(item);
var graphic = new Graphic(geometry);
graphic.setAttributes(attr);
features.push(graphic);
featureLayer.applyEdits(features, null, null);
function requestFailed(error) {
console.log('failed');
