Friend Function CreateFeatureClass(ByVal FCLocation As String, ByVal FCName As String, ByVal pSR As ESRI.ArcGIS.Geometry.ISpatialReference3, ByVal GeometryType As String) As ESRI.ArcGIS.Geodatabase.IFeatureClass Dim CreateFClass As New ESRI.ArcGIS.DataManagementTools.CreateFeatureclass Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Try Using releaser As New ESRI.ArcGIS.ADF.ComReleaser releaser.ManageLifetime(CreateFClass) CreateFClass.out_path = FCLocation CreateFClass.out_name = FCName CreateFClass.spatial_reference = pSR CreateFClass.geometry_type = GeometryType Result = RunTool(CreateFClass, Nothing, True) If Result Is Nothing Then Return Nothing Return ReturnObjectfromResult(Result, "Feature Class") End Using Catch ex As Exception System.Windows.Forms.MessageBox.Show(ex.ToString & vbNewLine & ex.StackTrace.ToString, "Create Feature Class") Return Nothing End Try End Function Friend Function ReturnObjectfromResult(ByVal result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Type As String) As Object Dim GPVal As ESRI.ArcGIS.Geodatabase.IGPValue Dim InMemFC As String Dim GPUtil As ESRI.ArcGIS.Geoprocessing.IGPUtilities3 = New ESRI.ArcGIS.Geoprocessing.GPUtilities Try GPVal = result.GetOutput(0) InMemFC = GPVal.GetAsText() Select Case Type Case "Feature Class" Return GPUtil.OpenFeatureClassFromString(InMemFC) Case "Table" Return GPUtil.OpenTableFromString(InMemFC) Case "Feature Layer" Return GPUtil.OpenFeatureLayerFromString(InMemFC) End Select Catch ex As Exception System.Windows.Forms.MessageBox.Show(ex.ToString, "Return FeatureClass error") Return Nothing End Try End Function Friend Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel, Optional ByVal AddOutput As Boolean = False) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult Try System.Windows.Forms.Cursor.Current = Windows.Forms.Cursors.WaitCursor Dim GP as New ESRI.ArcGIS.Geoprocessor.Geoprocessor GP.OverwriteOutput = True GP.AddOutputsToMap = AddOutput Result = CType(GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult) If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then Return Nothing End If Return Result Catch ex As Exception Return Nothing End Try End Function
