Since the new update this morning, i've been testing my develpment site out and I've come up with a few issues:
Any suggestions would be helpful,
Chris Boland
Hi Chris, let me answer these issues one at a time.
1. I've investigated and it's unclear what's happening here. I'm going to forward this along to our team for analysis.
2. This download is failing due to a known issue with ArcGIS Server. We have a workaround in place in Open Data, it should be deployed early next week.
3. I believe this is a browser specific setting. However, I have an idea for how we could give you the option to right click and save as, when you are retreiving large downloads. I'll talk to the team about getting that implemented.
I'll keep you updated here with regards to the 2 bugs and the enhancement. Let me know if you have any other questions.
Daniel
Thanks Daniel.
I think on #3, you're right. It is probably browser specific. I am using Firefox 34.0.5. I do get the save as option with Internet Explorer, and I do not have Chrome installed on my machine. I also have not tried Safari.
Thanks again,
Chris
Daniel,
I spoke with Andrew Stauffer over the phone yesterday and I think on #3 it is because my OpenData site had not been upgraded to the Bootstrap version yet. I believe once I upgrade my site, this concern will be addressed with the new "My Activity" download menu.
Thanks again for looking into this,
Hey Chris,
We have resolved issue number 1. You should be able to download that file without any future problems.
We are still working on issue 2. The extremely high vertex count per feature is presenting some challenges in converting the data into a shapefile or kml extract. If these features were simplified, the issue would not liekely arise. We want people to be able to download original source data so we're going to keep at it and I'll let you know when there are any updates.
Greetings Daniel,
I have been observing an interesting issue with an Open Data portal, which is none of the issue reported by Christopher, but that is pretty baffling.
On a particular Open Data portal, I have found a dataset of Planning Applications. When I check the Table tab, it reports a total of 33,096 features. However, when I download the data, either as CSV or as a shapefile, the downloaded datasets have double that number of features, or 66192. Closer examination of the downloaded datasets shows that the features seem to have been duplicated.
Have you heard and / or are you aware of this issue happening? If so, is there anyway to fix it?
Many thanks in advance.
@Miguel Paredes,
This issue has been reported on another geonet discussion (Open data downloads - duplicate records ). No answer has been provided yet.
Greetings Chris,
Many thanks for the link. As a matter of fact, it was Simon's site and the Planning Applications data set I was referring to. Interesting to find out that there are others, well, at least one more individual having the same issue.
Would be great to have a response from Esri on the issue, and how to resolve it.
Miguel
Hi Miguel,
I've fixed the dataset in question. We are having trouble reproducing this issue in our testing environment, but we are working on a fix nonetheless.
That is brilliant! Thank you very much for this.
Questions arise, is this caused by the size of the dataset in question? Or is it something else?
In any case, much appreciate the effort.
I am also having this issue. We are uploading a layer of parcels to open data with 163,462 rows (polygons). We do this monthly. This month for some reason, when we download the parcels, the number of polygons is correct, but there are holes in the data where some polygons are no longer present. The data must be getting lost in the download of the zip file. What is going on? The data is located ArcGIS Hub . The January dataset is also looking like it's affected now. Please let me know what the issue is. Thank you.
Hi Natalie,
I recommend opening up an issue with support so they can precisely scope the issue and further escalate to developers if necessary.
Daniel Fenton
ArcGIS Hub Team
