<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags"> <s:layout> <s:VerticalLayout paddingBottom="6"/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.events.GeometryServiceEvent; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import mx.controls.Alert; import mx.rpc.events.FaultEvent; import mx.utils.StringUtil; private var grGeometry:MapPoint = new MapPoint(); /** * Listen map mouse down handler */ protected function myMap_mapMouseDownHandler(event:MapMouseEvent):void { grGeometry = event.mapPoint; var geometriesToProject:Array = new Array(); geometriesToProject.push(grGeometry); var wkid:Number = NaN; /* var wkid:Number = 1314; */ var wkt:String = "GEOGCS[\"OSGB 1936\",DATUM[\"OSGB_1936\",SPHEROID[\"Airy 1830\",6377563.396,299.3249646,AUTHORITY[\"EPSG\",\"7001\"]],TOWGS84[375,-111,431,0,0,0,0],AUTHORITY[\"EPSG\",\"6277\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"DMSH\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9108\"]]"; var projectionSR:SpatialReference = new SpatialReference(wkid, wkt); sampleGeometryService.project(geometriesToProject, projectionSR); var gr:Graphic = new Graphic(grGeometry); var grId:String = myGraphicsLayer.add(gr); trace(StringUtil.substitute("Graphic with id: {0} added.", grId)); } /** * Listen geometry service project complete handler */ protected function onProjectComplete(event:GeometryServiceEvent):void { var pt:MapPoint = (event.result as Array)[0] as MapPoint; trace(event.result.toString()); Alert.show(StringUtil.substitute("From: x={0} \ny={1} \nSR={2}; \n\nTo: x={3} \ny={4} \nSR={5}", grGeometry.x, grGeometry.y, grGeometry.spatialReference.toString(), pt.x, pt.y, pt.spatialReference.toString()), "Projection result"); } /** * Listen geometry service fault handeler */ protected function onGeometryServiceFault(event:FaultEvent):void { trace(StringUtil.substitute("onGeometryServiceFault >> {0}", event.message)); Alert.show(event.fault.message, "Projection failt"); } ]]> </fx:Script> <fx:Declarations> <!-- Symbol for all point shapes --> <esri:SimpleMarkerSymbol id="sms" color="0x00FF00" size="12" style="{SimpleMarkerSymbol.STYLE_DIAMOND}"/> <esri:GeometryService id="sampleGeometryService" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" projectComplete="onProjectComplete(event)" fault="onGeometryServiceFault(event)"/> </fx:Declarations> <esri:Map id="myMap" mapMouseDown="myMap_mapMouseDownHandler(event)" level="3" wrapAround180="true"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer" symbol="{sms}"/> </esri:Map> </s:Application>
Using ArcGIS server REST Api to project geometries u can input only Well-known ID's (wkid) - as Input/Output Spatial Refences presented here. Using other Api's (Flex Api for expmple) you can create any own or exists Spatial Reference based on Well-Know Text (wkt) if ESRI Well-known ID (wkid) not exists. Tell me where I am wrong.
{"wkt":"PROJCS[\"OSGB 1936 / British National Grid\",GEOGCS[\"OSGB36\",DATUM[\"OSGB36\",SPHEROID[\"Airy 1830\",6377563.396,299.3249646,AUTHORITY[\"EPSG\",\"7001\"]],TOWGS84[446.448,-125.157,542.06,0.1502,0.247,0.8421,-20.4894],AUTHORITY[\"EPSG\",\"6277\"]],PRIMEM[\"Greenwich\",0.0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.017453292519943295],AXIS[\"Geodetic latitude\",NORTH],AXIS[\"Geodetic longitude\",EAST],AUTHORITY[\"EPSG\",\"4277\"]],PROJECTION[\"Transverse_Mercator\",AUTHORITY[\"EPSG\",\"9807\"]],PARAMETER[\"central_meridian\",-2.0],PARAMETER[\"latitude_of_origin\",49.0],PARAMETER[\"scale_factor\",0.9996012717],PARAMETER[\"false_easting\",400000.0],PARAMETER[\"false_northing\",-100000.0],UNIT[\"m\",1.0],AXIS[\"Easting\",EAST],AXIS[\"Northing\",NORTH],AUTHORITY[\"EPSG\",\"27700\"]]"}
