import arcpy, xlwt from arcpy import env from xlwt import Workbook # Set the workspace. Location of feature class or dbf file. I used a dbf file. env.workspace = "C:\data" # Use row object to get and set field values cur = arcpy.SearchCursor("SMU_Areas.dbf") # Set up workbook and sheet book = Workbook() sheet1 = book.add_sheet('Sheet 1') book.add_sheet('Sheet 2') # Set counter rowx = 0 # Loop through rows in dbf file. for row in cur: rowx += 1 # Write each row to the sheet from the workbook. Set column index in sheet for each column in .dbf sheet1.write(rowx,0,row.ID) sheet1.write(rowx,1,row.SHAPE_Area/10000) book.save('C:\data\MyExcel.xls') del cur, row
I've been spending the better part of the weekend trying to figure out the best way to transfer data from an personal geodatabase feature class into an Excel sheet using Python. I've found a few modules that may help (execsql, python-excel), but I'm not sure what the best approach should be.All I need to do is copy 4 columns of data from access to excel and then format the excel. I have the formatting part solved.Should I:Iterate through the rows using a cursor and somehow load the rows into excel?Copy the columns from access to excel?Export the whole access table into a sheet in excel?Thanks for any suggestions.
# first build the Microsoft Office Object library using the PythonWin makepy utility import win32com.client xl = win32com.client.Dispatch("Excel.Application") xl.Visible = 1 # good for testing things interactively wb = xlWorkbooks.Add() xl.ActiveSheet.Name = "Whatever" datasheet = xl.Worksheets("Whatever") # set format for text xl.Columns("A:A").NumberFormat = "@ # set format for lots of decimal places xl.Range(B2:ZZ45").NumberFormat = "0.0000000000" # setting a cell value datasheet.Cells(1, "A").Value = "SampleText" xl.ActiveWorkbook.SaveAs("C:\temp\Whatever.xlsx") xl.ActiveWorkbook.Close(SaveChanges = 1) xl.Quit()
