Hi Jason,As you noticed there are several approach to solve your issue:The easiest one I would say is to directly set a different PictureMarkerSymbol to each graphic.You could create a custom symbol. Look at the sample http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Custom_Symbol/01nq00000090000000/And the last one is using a renderer.The renderer is great to reuse the symbols and also to be able to break on several attributes of the Graphic.http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/renderers/package-detail.htmlMaybe the one you are looking for is the UniqueValueRenderer:http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/renderers/UniqueValueRenderer.htmlCreating a custom Renderer is also possible by implementing IRenderer.The function to implement is getSymbol(graphic:Graphic):SymbolInside your implementation you can do whatever you want to return a Symbol based on a Graphic.When the layer will draw, it will go through each Graphic and call that function to get the symbol to draw with.
