Hi Zachary,
Could you specify what you mean with the 'DWG to Shapefile tool'?
Peter
FME FTW!
(for the win)
Adrian Welsh
Hi Adrian, Just wanted to update you on this. Using the FME Safe DWG to shapefile conversion tool, I successfully converted the 3D .dwg to a shapefile with all the correct shapes and attributes, accurately georeferenced.
Adrian, Thanks for your response. The geometries that are showing up are in the correct location. It was mentioned in another thread that ArcPro does not support all 3D entities of AutoCAD. I am guessing this is my issue.
Zachary, are you still seeing geometry and is it in the right place?
I am having a similar issue. I have a bunch of polylines in civil saved as a .dwg (2013 version) which has been correctly imported into ArcPro. In AutoCAD Civil 3D they are created into 3D blocks (a network of pipes and valves). When I import the new .dwg into ArcPro, nothing is displayed and the features contain no attributes. It seems like there is some issue wen the polylines were converted to 3D models. Any Ideas?
Thanks!
Jim,
It appears that the AutoCAD 2018 version does not have compatible support for ArcGIS 10.5 (yet).
data - Autocad 2018 not compatible with ArcGIS desktop? - Geographic Information Systems Stack Exchange
Yes, I have been adding .dwg's to my ESRI maps just fine, then when I tried to add this address file it came in with no attributes. As I am looking at my .dwg file I'm not seeing an attribute table associated with it. I have an old address .dwg file that has attributes with it. Maybe I'm not creating the new .dwg correctly? I'm using ACADMap 2018 and ArcGis 10.5.
Also, thanks for the thread adequate. I'm not very familiar with these kind of help sessions.
I appreciate the help.
It is best to start a new thread when asking questions like this. In any case, take a look at these resources:
Adding CAD data to a map—Help | ArcGIS for Desktop
Importing CAD data in ArcGIS Desktop 10 | ArcGIS Blog
Have you tried these things and have not had success?
https://community.esri.com/groups/cadgis-data-integration?sr=search&searchId=394952e2-196a-49c2-bb82-eeda52fcd244&searchIndex=0
Can anyone tell me how to get the data from my .dwg to come in when added the .dwg to my ESRI map?
How did you get it to work?
Jon Kalantar escreveu:Never mind, got it! Thanks all!
How do you did it?
Is there a way to know what software version created the AutoCAD file? i'm having a similar issue where the attribute tables show no features in ArcMap, but when opened in AutoCAD Lt, there are features. We have tried exporting to earlier versions to no avail. There must be a setting in AutoCAD that is not allowing the features to be visible in ArcMap. Any ideas?
That's another one of my issues: there's no feature in the attribute tables. I'm importing directly as a dwg file into arcmap. And it definitely has a drawing in it when I open it in Autocad.
Even when I start a blank map and add the dwg data it doesn't show up. It must be that the drawing isn't georeferenced? How can I fix that?Thanks!
Hi all,I'm trying to import a CAD dwg file into ArcMap but when I do I don't see anything appear in the display. Also, the attribute tables for each layer (point, polyline, etc.) don't have any entries in them. Why is this happening??
