I published a points-layer as a runtime content (Cities layer, its table include a field for cities’ names: “[Name]”), how can I query features (Cities points) using their names which the user types in a text box (EditText)?
Please check out the sample:
Query Feature Service Table | ArcGIS for Developers
However, this sample is a query on GeodatabaseFeatureServiceTable. Since you mentioned that you published a points-layer as a runtime content, it should be GeodatabaseFeatureTable instead.
The difference between GeodatabaseFeatureServiceTable and GeodatabaseFeatureTable is:
In a connected workflow, the type of feature table you create and edit is a GeodatabaseFeatureServiceTable. In a disconnected workflow, the type of feature table you create and edit is a GeodatabaseFeatureTable. The class hierarchy between these is GeodatabaseFeatureServiceTable is inherited from GeodatabaseFeatureTable.
Now let's go over the code:
In onClick_okButton method:
// Create query parameters, based on the constructed where clause.
QueryParameters queryParams = new QueryParameters(); queryParams.setWhere(whereClause);
// Execute the query and create a callback for dealing with the results of the query. featureServiceTable.queryFeatures(queryParams, new CallbackListener<FeatureResult>() { @Override public void onError(Throwable ex)
{ // Highlight errors to the user.
showToast("Error querying FeatureServiceTable"); }
@Override public void onCallback(FeatureResult objs)
{ // If there are no query results, inform user.
if (objs.featureCount() < 1) { showToast("No results"); return; }
// Report number of results to user.
showToast("Found " + objs.featureCount() + " features.");
// Iterate the results and select each feature.
for (Object objFeature : objs) { Feature feature = (Feature) objFeature; featureLayer.selectFeature(feature.getId()); } } }); }
Note that featureServiceTable.queryFeatures, you can change it to GeodatabaseFeatureTable.queryFeatures, and set up the parameters in QueryParameters.
See the API reference for the detailed information:
GeodatabaseFeatureTable | ArcGIS Android 10.2.4 API
Let me know if you have any questions.
Dear Mengyi,
Thank you very much for your massive contribution, I tried this code, and it worked well!
Thank you again and Best Regards,
Hani
