Anyway if Python does it that is nice, but only about 20 people on this forum could have come up with that solution. I demand solutions from ESRI that are designed for non-programmers to do a basic operation like data conversion involving a recasting of a field. Resorting to Python as the only option is unacceptably unfriendly from my perspective.
From what I understand, the data source is a non-spatial table in an Oracle database. I am not exactly sure how to use the Feature Class to Feature Class tool in this instance as the source is simply attributes not registerd with any SDE. Also, from the docs, http://resources.arcgis.com/en/help/main/10.1/index.html#//001200000027000000 the Table to Table conversion input data types does not seem have an Oracle table as an option either.The OP is going to have to perform some way to connect and query the data source, then create some mechanism that will transform the result to an output format desired or needed (my example shows that it will be saved as a GDB table).
Why is Python needed at all to create a new feature class/table that converts the field types? As long as you are disconnecting from the source data why not just use the Feature Class to Feature Class tool or the Table to Table tool? They can alter the field map type of the coordinate fields from string to double and output a new FC/table and perform the desired conversion directly to the new output.It is only if you want to use the original source and maintain a connection to it that you have to look for alternatives outside of ArcMap. For those you need to set up the on the fly conversion on the server side.
import arcpy import cx_Oracle import numpy as np ### Build a DSN (can be subsitited for a TNS name) dsn = cx_Oracle.makedsn(param1, param2, param3) oradb = cx_Oracle.connect("username", "password", dsn) cursor = oradb.cursor() sqlQry = """SELECT MyTableOrView.SomeField1 AS SomeTEXTField, CAST(TO_CHAR(MyTableOrView.x_coords, 'fm9999999.90') AS FLOAT) AS x_coords, CAST(TO_CHAR(MyTableOrView.y_coords, 'fm9999999.90') AS FLOAT) AS y_coords FROM MyTableOrView""" cursor.execute(sqlQry) datArray = [] cxRows = cursor.fetchall() for cxRow in cxRows: datArray.append(cxRow) #close the conn to ora cursor.close() oradb.close() del cxRows, cursor numpyarr_out = np.array(datArray, np.dtype([('SomeTEXTField', '|S25'), ('x_coords', '<f8'), ('y_coords', '<f8')])) #convert the numpyarray to a gdb feature class outFC = r'C:\MyGDB\xyPoints_FromStrings if arcpy.Exists(outFC): arcpy.Delete_management(outFC) arcpy.da.NumPyArrayToFeatureClass(numpyarr_out, outFC, ("x_coords", "y_coords"))
import arcpy import cx_Oracle import numpy as np ### Build a DSN (can be subsitited for a TNS name) dsn = cx_Oracle.makedsn(param1, param2, param3) oradb = cx_Oracle.connect("username", "password", dsn) cursor = oradb.cursor() sqlQry = """SELECT MyTableOrView.SomeField1 AS SomeTEXTField, CAST(TO_CHAR(MyTableOrView.x_coords, 'fm9999999.90') AS FLOAT) AS x_coords, CAST(TO_CHAR(MyTableOrView.y_coords, 'fm9999999.90') AS FLOAT) AS y_coords FROM MyTableOrView""" cursor.execute(sqlQry) datArray = [] cxRows = cursor.fetchall() #close the conn to ora cursor.close() oradb.close() del cursor numpyarr_out = np.array(cxRows, np.dtype([('SomeTEXTField', '|S25'), ('x_coords', '<f8'), ('y_coords', '<f8')])) #convert the numpyarray to a gdb feature class outFC = r'C:\MyGDB\xyPoints_FromStrings if arcpy.Exists(outFC): arcpy.Delete_management(outFC) arcpy.da.NumPyArrayToFeatureClass(numpyarr_out, outFC, ("x_coords", "y_coords"))
ArcMap does not support casting of data fields at all except in pure SQL statements. The tool input that are not where clauses are not SQL based. The field is string and that is all ArcMap can use it as. ArcMap can only create a new field that is numeric. It cannot do anything to make your string field numeric. This limitation has been complained about by every user for over a decade and ESRI won't take it on.You have to convert it at the database level apart from any ESRI tools. ESRI won't write tools to do that for you. You are stuck either creating new fields or disconnected copies of the entire data table using Table to Table to recast the field to numeric inside of ArcMap.ESRI makes sure everything else results in errors. Only a purely text based input like a cvs or txt file is converted to numeric by the tool on the fly. If it detects that the input is a true data table it won't do that. You would not be the first person ESRI told to suck it up and make major schema changes outside of their product to make their product work and you won't be the last.Data conversions to make ESRI tools work feels like it is practically 50% of my job to use ArcMap at all if I have to deal with any data created outside of ArcMap by people who did not care about ESRI's data rules. The only benefit of being forced to adhere to these strict requirements is that adhering to their rules does translate into the best performance once I make the conversions. When ESRI attempts to accommodate such conversions on the fly the performance degradation is usually so severe I end up making the database level conversions anyway to stay sane.In fact I won't use Excel, cvs or txt files without conversion even though they are supported, because the performance boost of using a real numeric field in a real database table is dramatic and inevitably these formats impose some use restriction that I cannot live with at some point if the data inside of them is at all valuable for my job.
float( !XField!) is what you have to use from the calculate field tool. If you running it right in python, try this:float(Xstr)Where Xstr is your X value as a string.
float(Xstr)
I tried this from a Python version of the code. I didn't work it gave me syntax errors.
Are you trying to make points with the X and Y fields? Or are they simple to be used as a data field for your records?You could use the Add Field tool to make two numeric X and Y fields and then use the Calculate field tool to convert the string field to a number. You could probably skip the add field tool if you are confident that all the records will convert without error.Your expression could be something like:float( !XField!)Let me know if that helps at all.
float( !XField!)
That's my bad. Missed it.Well... I wonder if you can perform the conversion directly in the SQL as part of the MakeQueryLayer_management implementation. I will hunt around to see if there are examples.My thought is, can you issue a "CAST" or "TO_NUMBER" statement in the sql somewhere?Edit: I noticed that you are attempting to implement MakeQueryTable! Man, that stuff just looks messy. If it were me, I'd go towards python script and implement the cx_Oracle library --- you have so much more control. I know that is outside of the bounds for your OP and sorry I don't have a good solution other than this. BUT, the cx_Oracle lib is very awesome 🙂
Apologies, I should have included that info. as it is important; I'm using the Make Query Table tool.
How exactly are you "sucking in" the Oracle data as you mentioned in your OP?
Unfortunately this isn't an option as it is an third party application database. Any tampering would breach our support agreement 😞
Fix the database, it's that important. I just see no value in doing gymnastics to wrestle things that should be modeled for what they are at the database tier.If it's a date, store it as such. Decimals, floats, integers? Then that's what they are period. Get with the database admin, and make it right. You will save yourself tons of headaches, not just in the immediate, but long-term life-cycles of the tools and applications you build will be better off.
