Hi,Check the following key in regedit to 10.5.1:HKEY_CURRENT_USER\Software\ESRI\Desktop10.5\SDE Workspace Factory
10.2.1HKEY_CURRENT_USER\Software\ESRI\SDE Workspace FactoryEdit key INSTANCE. Remove VERBOSE=TRUE
Does anybody know how to do this oracle instaclient connections? When I try to add ;SDEVERBOSE=TRUE using an oracle connection it give me an error message about server not being found.
How do you turn off the SDEVERBOSE?
I followed your instructions for setting SDEVERBOSE to true. After testing I went back into the database connection but the ;SDEVERBOSE=TRUE section was gone SDE layers added to lyr files still show it as TRUE therefore I added ;SDEVERBOSE=FALSE to the connection and resourced the feature class in the lyr file, but now it reads ;SDEVERBOSE=FALSE;SDEVERBOSE=TRUE
I;m running 10.1 SP1
Hi,it should be the same procedure as in previous releases, adding the parameter in your dbinit.sde filehttp://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//002n00000017000000Regards,
