I am using ArcGIS 10. I successfully converted an Illustrator file to DXF, added it to an ArcMap project file, and exported the polygon layer to a shapefile. Using the spatial adjustment tool, I chose an Affine transformation and created several links from the new shapefile to an existing data layer.However, "adjust" is inactive -- so I can't perform the adjustment. What could cause this?
I'm aware that going from arcgis -> illustrator is quite common. But I have the inverse problem.I have some vectors in illustrator that I want to open in arcgis. I tried to save in various autocad options but not once did they appear in arcgis, even though I checked the autocad layers and all the vector points were there.Here are the files.pdf http://docs.google.com/leaf?id=0B9wNtQ9NGRHuNmExYzA2NzEtOWZlYS00ZDViLTk2OTgtNDY4ZWE5YTNiZmUz&hl=en&authkey=COa3y7gCai http://docs.google.com/uc?id=0B9wNtQ9NGRHuNmVkMjZjZWEtMTc2Ny00NDE3LTgxNmMtNTk0NTliMDA0OTFi&export=download&authkey=CIHK_5gE&hl=ensvg http://docs.google.com/uc?id=0B9wNtQ9NGRHuMGRhYjQ1NDAtMzk5MS00ZDQ1LWIzYWUtM2E2NjM1OGRiODhj&export=download&authkey=CLyKoc0I&hl=enIf someone can tell me why the autocad import doesn't work that would be really helpful.Thanks
