OK, so you normally don't create login pages, you just secure the folders in IIS that host the apps using AD restrictions? In that case I guess the .NET wrapper would be overkill. Are the mapservices you are using in your flex app hosted on a different server? If so you should include a crossdomain.xml file on the root of your app server. This is venturing a little of my own comfort zone as I am a total newbie at all the flex stuff myself. I havent had this problem as my app and map services are all on the same server. However I believe that if they are not hosted together then the crossdomain.xml is the way to go. I found an example of one and it looks like this:<?xml version="1.0" ?> - <cross-domain-policy> <allow-access-from domain="*" /> <site-control permitted-cross-domain-policies="all" /> <allow-http-request-headers-from domain="*" headers="*" /> </cross-domain-policy>i think this format allows access to all domains, I'm not sure exactly how you would tailor it to your own needs. Perhaps a search on here / google will help you further. I'm afraid this is the limit of my knowledge on this one, but it might be of use? Hope it helps a bit!If not then hopefully someone wiser than me will sort you out 🙂
hi t0ny (btw it's Graham 😄 )You don't HAVE to have the interim page, you can of course direct straight from your login.aspx to your flex.aspx on successful login. Also you can secure the flex.aspx page so it cannot be accessed by unauthenticated users directly with a URL, probably the simplest way is to put the page in its own folder in the .net website folder structure and use the asp.net website security to restrict access to that folder (in visual studio open the asp.net website and go to website /asp.net authentication on the toolbar) and it's all taken care of for you in a nice little UI that is very easy to understand.If you are unsure on all this there are absolutely hundreds of articles and code snippets you can use. Read up on the roles and membership apis on msdn.Hope this helps you. ps: Yes the resizing code works for IE6, although I haven't tested it on a range of different monitor resolutions, im pretty sure it's ok. It isn't actually my own resizing code, i found it somewhere on the net when i needed something similar for a .net project i was working on.
Tony,I am not sure how to do this directly in flex, however if you (or someone on your team) is familiar with asp.net I would advise creating a .NET "wrapper site" for the login functionality. Once the user is successfully logged in, you can then redirect to your flex app which can be hosted in an aspx page in your website like so:button on page displayed once user is logged in:Protected Sub btnGo_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles btnGo.Click 'uncomment accordingly: 'redirect 'Response.Redirect("myflex.aspx") 'or open in new window: 'Response.Write("<script type='text/javascript'>detailedresults=window.myflex.aspx');</script>") End Subthen in your "Myflex.aspx' you can do the following (nb all the javascript allows for displaying this full size in IE since if you try to set height as a percentage in ie it doesnt work!!)<!-- HTML "object" element has a problem with height attribute (when using %) in IE. Therefore implement a script to resize the object in the window so that the flex app fills the window correctly--> <script type="text/javascript"> function pageY(elem) { return elem.offsetParent ? (elem.offsetTop + pageY(elem.offsetParent)) : elem.offsetTop; } function resizeObjectContainer() { var buffer = 20; //scroll bar buffer var height = document.documentElement.clientHeight; height -= pageY(document.getElementById('swfContainer'))+ buffer ; //height -= pageY(document.getElementById('DisplayFrame')); height = (height < 0) ? 0 : height; document.getElementById('swfContainer').style.height = height + 'px'; //resizeDebug(); } </script> <body onload="resizeObjectContainer();" onresize="resizeObjectContainer();"> <form id="form1" runat="server"> <div> <object id="swfContainer" classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width=100%> <param name="movie" value="cawdapt_v1a.swf"/> </object> </div> </form> </body> </html>you could also look at this thread, a few people there recommended .net wrapper as the way to go.
