Hello, I run the model using ADD JOIN instead of JOIN FIELD tool but the result is the same (i.e., it is slower than when I worked with shapefiles). The problem I think is the copy features tool (at the end of the process). It takes four hours to process this step. Any recomendation?I send you a better version of the Model Builder:[ATTACH=CONFIG]28510[/ATTACH] Thank you very much.
Hi,I have joined an excel table to a shapefile with multiple registers (more than 200,000) and I�??m trying to export it as a new shapefile but it takes more than 4 hours to do it. Does anybody know another way to do it?I have to repeat the process more that 16 times (using Model Builder) and I need to find a faster way to do it. Any help will be much appreciated !!Thank you.
Thanks for your answer. It seems very promising but ... I haven't worked with geodatabase files. Could you please explain me more in detail these steps ?? Thank you very much!!
Hello, Thanks for the explanation. I was able to run the model, but ... unfortunately is not running faster than before. I send you the Model I have generated and I would really appreciate your feedback if you find any error. [ATTACH=CONFIG]28443[/ATTACH]. Some specific questions I was not sured when I generate the model: 1. I use the tool Join Field and not Add field in the model. Is that correct ?2. When I used the Copy Feature tool I saved the feature within the geodatabase folder. Is that correct ?3. In the last step (Feature Class to Feature Class tool), I was not sured how I had to do it, so I saved the final shapefile in a folder, NOT in the geogatabase folder. Is that correct ???Thank you very very much.
Yes, that was it. I created a File Geodatabase and now it only takes 5 minutes to conduct the join and create the shapefile. That is great !!Thank you very much for all your help !
For Excel use the Table to Table tool to copy it into your new geodatabase, also in the Conversion toolbox and the Geodatabase toolset. Use the Add Attribute Index tool under the Data Management toolbox in the Indexes toolset on the Join fields in both the new feature class and the table to optimize the join performance. Use the Make Feature Layer tool on the converted shapefile feature class. Use the Join tool with that layer as the input layer and the geodatabase table as the join source.
Thanks for the detailed info. I have a bit of a different problem and I think this might help. Does this sound like it would work?I have a file geodatabase feature class joined with an Excel table and set up in data driven pages. When I try to export selected records to pdf it gives an error. The problem has something to do with the join because it works as soon as I remove the join. I want to try your idea of importing the table to geodatabase to see if that fixes it. I don't want to set up the join all over again each time the Excel table is updated. So I think I would work from ArcCatalog to overwrite the join data with the same name without opening the mxd. Sound good? (This is in 10.0.)Also is there a difference between the add join from the toolbox, and the add join from right-clicking the layer in the TOC?
That will work if you create a model to do the update. The Add Join is the same, other than one operates in a model and the other is made visible in desktop. If the model ran while the map was closed and afterward the map was open, it should open everything just fine as long as the data sources and file names had not changed.
Cool, thanks. I will give this a try.
