You can do 3 things (listed in order of recommendation) ...1) Use the Table raster type to add your mosaic datasets into the new mosaic dataset.Run the Synchronize Mosaic Dataset tool when you've updated the original mosaic datasets, to make sure the new mosaic dataset is updated. (This can affect the fields you've added)2) Use the Raster Dataset raster type to add your mosaic datasets into the new mosaic dataset. This works ok when you're not adding too many. Max mosaic datasets in a mosaic dataset using this raster type is 8.3) If you're adding the image service created from the mosaic dataset, then you'll use the Web Services raster type.
