Dear Friends,
Kindly find the attached multiple mdb's. how to delete multiple mdb or gdb empty features class.any code available please help me.
Santhosh
http://pro.arcgis.com/en/pro-app/arcpy/functions/listfeatureclasses.htm
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> <SPAN class="operator token"><</SPAN>workspace<SPAN class="operator token">></SPAN> fcs <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'*'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> fc <SPAN class="keyword token">in</SPAN> fcs<SPAN class="punctuation token">:</SPAN> test <SPAN class="operator token">=</SPAN> int<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>GetCount_management<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>getOutput<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Feature Count: {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>test<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> test <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Deleting Feature Class: {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
To add onto the concepts covered by @James, the following will take an input directory and loop over the gdbs and FCs for each one.
<SPAN class="keyword token">import</SPAN> arcpy <SPAN class="keyword token">import</SPAN> os inputDir <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'path\to\directory\that\houses\geodatabases'</SPAN> ext <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'.mdb'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'.gdb'</SPAN><SPAN class="punctuation token">]</SPAN> gdbs <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>x <SPAN class="keyword token">for</SPAN> x <SPAN class="keyword token">in</SPAN> os<SPAN class="punctuation token">.</SPAN>listdir<SPAN class="punctuation token">(</SPAN>inputDir<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> x<SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">in</SPAN> ext<SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> g <SPAN class="keyword token">in</SPAN> gdbs<SPAN class="punctuation token">:</SPAN> fullpath <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>inputDir<SPAN class="punctuation token">,</SPAN> g<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> fullpath <SPAN class="keyword token">for</SPAN> fc <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> rowCount <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetCount_management<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">if</SPAN> rowCount <SPAN class="operator token">==</SPAN> <SPAN class="string token">'0'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Deleting empty FC: {0}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>g<SPAN class="punctuation token">,</SPAN>fc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>fullpath<SPAN class="punctuation token">,</SPAN>fc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"{0} contains {1} records"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>g<SPAN class="punctuation token">,</SPAN>fc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> rowCount<SPAN class="punctuation token">)</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Did you forget about this one?
https://community.esri.com/thread/197602-how-to-delete-the-empty-feature-class-from-gdb-or-mdb-arcgis-1041
Hi Dear,
attached below snapshot can you give the solution for attached image.Delete multiple mdb empty feature class one time all mdb.
You are using filename in the listing of extensions. Just use the extension:
ext <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'.mdb'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'.gdb'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
If the file ends in either of these extensions, then the filename will be found. Also, you need to set the inputDir to the correct value.
Change the inputDir path to the directory that houses your geodatabases...
