# Import modules and create the geoprocessor object import arcgisscripting, sys, os gp = arcgisscripting.create() gp.workspace = os.getcwd() # File to process shp = "File1.shp" # Set total to zero and start a blank list total=0 keepTrack=[] # Create update cursor for feature class. rows = gp.UpdateCursor(shp) row = rows.Next() while row: # Get the values from the fields id = row.GetValue("ID") len = row.GetValue("LENGTH") # If id is unchanged if id in keepTrack: # Add length to the total total = total + len # If id changes if not id in keepTrack: # Total starts over as length value total = len # Clear the id list keepTrack=[] # Keep track of the id keepTrack.append(id) print "id: "+str(id), "length: "+str(len), "total: "+str(total) # Write the total to field "CUM_LENGTH" row.CUM_LENGTH = total # Execute the new value to the table rows.UpdateRow(row) # Go to the next row = rows.Next() del rows
Here's the code with the proper indenting (I finally figured out how to post code properly on this new site).# Import modules and create the geoprocessor object import arcgisscripting, sys, os gp = arcgisscripting.create() gp.workspace = os.getcwd() # File to process shp = "File1.shp" # Set total to zero and start a blank list total=0 keepTrack=[] # Create update cursor for feature class. rows = gp.UpdateCursor(shp) row = rows.Next() while row: # Get the values from the fields id = row.GetValue("ID") len = row.GetValue("LENGTH") # If id is unchanged if id in keepTrack: # Add length to the total total = total + len # If id changes if not id in keepTrack: # Total starts over as length value total = len # Clear the id list keepTrack=[] # Keep track of the id keepTrack.append(id) print "id: "+str(id), "length: "+str(len), "total: "+str(total) # Write the total to field "CUM_LENGTH" row.CUM_LENGTH = total # Execute the new value to the table rows.UpdateRow(row) # Go to the next row = rows.Next() del rows
# Import modules and create the geoprocessor object import arcgisscripting, sys, os gp = arcgisscripting.create() #gp.workspace = os.getcwd() gp.workspace = sys.argv[1] # File to process shp = sys.argv[2] # Set total to zero and start a blank list total=0 keepTrack=[] # Create update cursor for feature class. rows = gp.UpdateCursor(shp) row = rows.Next() while row: # Get the values from the fields id = row.GetValue("ID") len = row.GetValue("LENGTH") # If id is unchanged if id in keepTrack: # Add length to the total total = total + len # If id changes if not id in keepTrack: # Total starts over as length value total = len # Clear the id list keepTrack=[] # Keep track of the id keepTrack.append(id) print "id: "+str(id), "length: "+str(len), "total: "+str(total) # Write the total to field "CUM_LENGTH" row.CUM_LENGTH = total # Execute the new value to the table rows.UpdateRow(row) # Go to the next row = rows.Next() del rows
