Does anyone know if this is attachment functionality is now working in 10.1 as promised?
Hi AkhilP,I tried to reproduce the issue of mobile application at 10 doesn't show blob field that has field name starting with "picture_", but with no avail. Both Windows and Windows Mobile application treat them as picture and offered options to take a photo (WM only) or browse to select a photo.By default blob field will be not be shipped to mobile client. You can manually change this by taking a looking at the Fields tab on the layer's property dialog. Make sure the blob field is checked.Let me know if this still doesn't work for you.-Jay
If you found blob filed missing from your mobile cache, one possible reason is that the blob field is not "checked" in your mxd. In ArcMap, if you bring up the layer property and go to "Fields" tab, make sure your blob field is checked. Mobile service will only ship those fields that are checked to client. By default the blob field is checked off in mxd.
We've been working on attachment support and that's why you see some attachment API exposed at 9.3.1 on mobile SDK. However at 10 final release the attachment support is not fully implemented so we decided to keep it internal.
Just want to follow up with you on your use case. We are working on attachment support and would like to learn a bit more details on how your user uses attachment. As I understand, you need to save CAD document as an attachment and ship it to client.- Are your clients using tablet mobile application or windows mobile application?- Once attachment is shipped to client, they need to view it? If so, they need to have appropriate application installed on their tablet/wm device? And only need to view or also needs editing capability?- What kind of CAD document are we talking here?Thanks for your input.
I am looking for hours for a possibility synchronizing attachments with arcgis server and could not find anything useful.What I need is:We have to sync CAD documents to clients. Therefore I want to use the ArcGIS Mobile Sync mechanism.For 9.3 I could find some classes for attachments (ESRI.ArcGIS.Mobile.MobileServices.AttachmentInfo and ESRI.ArcGIS.Mobile.MobileServices.FeatureAttachmentManager). I do not know how this is what I am looking for, but this classes are not existing in Mobile 10 any longer, so it make no sense to go deeper in it.So: What is the way to adminster attachments on ArcGIS Mobile 10?
Hi,I read this post, at first I didn't understand what you mean by "Attachment". Now it seems like you want to simply attach an image/photo to the feature you are collecting.1) In ArcCatalog you can Add a Raster field (you have already done) in which you can add an image to your feature. The image attached in the field is of a Bitmap variable. I believe you got a handle of this. But are you stating this doesn't work for some reason? Can you elaborate some more as to if or if not this Raster field is working for you?2) The second way to have "attachments" is blob fields, also added through ArcCatalog. According to the documentation I found/lack there of, the name of the blob field must be "Picture_<something>".You can find my post inside the thread here with the name of Photo in Mobile 10, something like that.However, I tried this and it did not work, even with the proper naming convention of "Picture_<something>" I still couldn't see that field in the attribute entry in ArcGIS Mobile 10.Either we may be doing something wrong or this feature seems to not work correctly or at all.Also by using the blob field and the naming convention, you would be allowed to attach as many image/photos you want to the feature. However with the raster field you will only be allowed 1 image/photo per feature. (Provided that the blob field thing worked)
Less knowledge so far ... as I expected.Now I tried to create a new feature class and added a Blob field where I want to save my attachments. Also I added a Raster field for testing.Then I tried on the client to save data to this fields. In the Raster field I could not save binary data, only bitmap. So, photos can be saved.But - where is my Blob field? If I look my layer's table, the Blob field is missing!? No idea why.I added two Blob fields for testing, both were not present on mobile client. Could Mobile 10 not work with Blob? FileStream fs = new FileStream(@C:\temp\MapCaches\Mobile10Tests\zeitplan.pdf, FileMode.OpenOrCreate, FileAccess.Read); byte[] data = new byte[fs.Length]; fs.Read(data, 0, Convert.ToInt32(fs.Length)); fs.Close(); Bitmap bitmap = new Bitmap(@C:\temp\MapCaches\Mobile10Tests\bild.jpg); var table = ((FeatureLayer) mobileService2.Layers["Attachments"]).GetDataTable(); var row = table.NewRow(); row["Raster1"] = bitmap; //-> works row["Binary1"] = data; //-> no Binary1 field found! table.Rows.Add(row); table.SaveInFeatureLayer();
