//////////////////////////////////////////////////////////////////////////////// // // Copyright © 2008 ESRI // // All rights reserved under the copyright laws of the United States. // You may freely redistribute and use this software, with or // without modification, provided you include the original copyright // and use restrictions. See use restrictions in the file: // <install location>/FlexViewer/License.txt // //////////////////////////////////////////////////////////////////////////////// package com.esri.solutions.flexviewer.components.toc.tocClasses { import com.esri.ags.events.ExtentEvent; import com.esri.ags.layers.LayerInfo; import com.esri.solutions.flexviewer.SiteContainer; /** * A TOC item representing a member layer of an ArcGIS or ArcIMS map service. * This includes group layers that contain other member layers. */ public class TocLayerInfoItem extends TocItem { public function TocLayerInfoItem( parentItem:TocItem, layerInfo:LayerInfo) { super(parentItem); _layerInfo = layerInfo; label = layerInfo.name; // Set the initial visibility without causing a layer refresh setVisible(layerInfo.defaultVisibility, false); SiteContainer.getInstance().controller.map.addEventListener(ExtentEvent.EXTENT_CHANGE,checkExtent); } internal static const DEFAULT_MAX:Number = 0; private var _maxScale:Number = DEFAULT_MAX; public function set maxScale( value:Number ):void { _maxScale = value; this.scaledependant = true; if(_maxScale > 0 && _minScale > 0){ if ((SiteContainer.getInstance().controller.map.scale >= _maxScale) && (SiteContainer.getInstance().controller.map.scale <= _minScale)){ this.scaledependant = false; } } else if (_maxScale > 0 ){ if ((SiteContainer.getInstance().controller.map.scale >= _maxScale)){ this.scaledependant = false; } } else if (_minScale > 0 ) { if ((SiteContainer.getInstance().controller.map.scale <= _minScale)){ this.scaledependant = false; } } else { this.scaledependant = false; } } public function get maxScale():Number { return _maxScale; } private function checkExtent(evt:ExtentEvent):void{ this.scaledependant = true; if(_maxScale > 0 && _minScale > 0){ if ((SiteContainer.getInstance().controller.map.scale >= _maxScale) && (SiteContainer.getInstance().controller.map.scale <= _minScale)){ this.scaledependant = false; } } else if (_maxScale > 0 ){ if ((SiteContainer.getInstance().controller.map.scale >= _maxScale)){ this.scaledependant = false; } } else if (_minScale > 0 ) { if ((SiteContainer.getInstance().controller.map.scale <= _minScale)){ this.scaledependant = false; } } else { this.scaledependant = false; } } internal static const DEFAULT_MIN:Number = 0; private var _minScale:Number = DEFAULT_MIN; public function set minScale( value:Number ):void { _minScale = value; this.scaledependant = true; if(_maxScale > 0 && _minScale > 0){ if ((SiteContainer.getInstance().controller.map.scale >= _maxScale) && (SiteContainer.getInstance().controller.map.scale <= _minScale)){ this.scaledependant = false; } } else if (_maxScale > 0 ){ if ((SiteContainer.getInstance().controller.map.scale >= _maxScale)){ this.scaledependant = false; } } else if (_minScale > 0 ) { if ((SiteContainer.getInstance().controller.map.scale <= _minScale)){ this.scaledependant = false; } } else { this.scaledependant = false; } } public function get minScale():Number { return _minScale; } //-------------------------------------------------------------------------- // Property: layerInfo //-------------------------------------------------------------------------- private var _layerInfo:LayerInfo; /** * The map layer info that backs this TOC item. */ public function get layerInfo():LayerInfo { return _layerInfo; } //-------------------------------------------------------------------------- // // Methods // //-------------------------------------------------------------------------- /** * @private */ override internal function setVisible( value:Boolean, layerRefresh:Boolean = true ):void { // Set the visible state of all children, but defer the layer refresh for each (var item:TocItem in children) { item.setVisible(value, false); } // Set the visible state of this item, but defer the layer refresh super.setVisible(value, false); // Allow the layer refresh now that all changes have been made if (layerRefresh) { refreshLayer(); } } } }
