I didn't know about "set" before, so nice post. I saw it because this popped up in my geonet email, but notices a syntax error above, and then expanded for a non-dupe list. fwiw.
list <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">64</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">32</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> len<SPAN class="punctuation token">(</SPAN>list<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token"><></SPAN> len<SPAN class="punctuation token">(</SPAN>set<SPAN class="punctuation token">(</SPAN>list<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"the list provided contains duplicate values"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"no dupes"</SPAN><SPAN class="punctuation token">)</SPAN> list <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> len<SPAN class="punctuation token">(</SPAN>list<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token"><></SPAN> len<SPAN class="punctuation token">(</SPAN>set<SPAN class="punctuation token">(</SPAN>list<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"the list provided contains duplicate values"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"no dupes"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
edit: ....oops...I missed Doug's and Dan's examples. shows you what happens when you go to the bottom of the geonet comments first.
list = ( 2, 8, 64, 16, 32, 4, 16, 8) if len(list) <> len(set)list): print "The list provided contains duplicate values"
If anyone can help me with this I really would appricate it. I'm a novice My task is to create a script a that examines a list of numbers (for example, 2, 8, 64, 16, 32 4, 16, 😎 to determine whether it contains duplicates. The script should print a meaningful result, such as "The list provided contains duplicate values" or "The list provided does not contain duplicate values."Thanks,Larry
>>> a = ( 2, 8, 64, 16, 32, 4, 16, 8) >>> b = set(a) >>> if len(b) < len(a): ... print "contains duplicates" ... else: ... print "no duplicates found:" >>> contains duplicates
Something like this should do the trick: def FindDuplicates(in_list): unique = set(in_list) for each in unique: count = in_list.count(each) if count > 1: print 'There are duplicates in this list' return True print 'There are no duplicates in this list' return False
Cur = arcpy.da.SearchCursor(InFc, ["Field"]) # where Field is the column to count duplicates FDict = {} for r in Cur: f = r[0] if f in FDict: FDict += 1 else: FDict = 1 del Cur
def FindDuplicates(in_list): unique = set(in_list) for each in unique: count = in_list.count(each) if count > 1: print 'There are duplicates in this list' return True print 'There are no duplicates in this list' return False if __name__ == '__main__': # test it a = [8, 64, 16, 32, 4, 24] b = [2,2,3,6,78,65,4,4,5] FindDuplicates(a) FindDuplicates(b)
import collections def has_duplicates(list_of_values): value_dict = collections.defaultdict(int) for item in list_of_values: value_dict[item] += 1 return any(val > 1 for val in value_dict.itervalues()) if has_duplicates(my_list): print "The list provided contains duplicate values" else: print "The list provided does not contain duplicate values."
