public void ReLoadMeters(string sql) { /* Retrieve meters for the alert type check box status */ ESRI.ArcGIS.Client.FeatureLayer fs = new ESRI.ArcGIS.Client.FeatureLayer(); // Set event handler on feature layer feature retrieval. fs.UpdateCompleted += FeatureLayer_UpdateCompleted; fs.Url = MetersFeatureService; if (!string.IsNullOrWhiteSpace(sql)) fs.Where = sql; fs.Mode = FeatureLayer.QueryMode.OnDemand; fs.Renderer = AlertTypesRenderer; fs.OutFields.Add("*"); fs.Visible = true; fs.ID = MetersMapName; // Add the new meters to the map. Remove the old layer first int index = MyMap.Layers.IndexOf(MyMap.Layers[MetersMapName]); if (index >= 0) { try { MyMap.Layers.RemoveAt(index); MyMap.Layers.Insert(index, fs); } catch { } } } private void FeatureLayer_UpdateCompleted(object sender, EventArgs args) { // Create instance of feature layer that just returned features from ArcGIS Cloud Server ESRI.ArcGIS.Client.FeatureLayer fs = sender as ESRI.ArcGIS.Client.FeatureLayer; // Clear graphics layer bound to feature data grid _myFeatureDataGridLayer.ClearGraphics(); // Fill graphics layer for feature data grid // Iterate through every feature sent by feature service foreach (ESRI.ArcGIS.Client.Graphic graphic in fs.Graphics) { // Create a new graphic instance to prevent OutOfRangeException silent errors. ESRI.ArcGIS.Client.Graphic gr = new ESRI.ArcGIS.Client.Graphic(); // Retrieve geometry gr.Geometry = graphic.Geometry; // Iterate through every attribute and copy it to new graphic. foreach (KeyValuePair<string, object> kvp in graphic.Attributes) { gr.Attributes.Add(kvp); } // Insert new graphic to graphics layer bound to feature data grid _myFeatureDataGridLayer.Graphics.Insert(0, gr); } }
