Is there a way to change the position of the popup window, or drag it with your mouse out of the way. As it is now the popup window open where you click and you cant move it at all. I know in Flex you could move it with the mouse.
George,
As of right now there is not a way to move the popup. I agree that this would be very helpful. Here is a thread that talks a little about this. You may find it helpful/interesting.
How do I edit pop-up size and location?
-Stan
Just checking in... Has the recent release changed our ability to modify the defaults on popup window placement? I'm not concerned about size in this case, more about being able to back the popup off from the highlighted feature a bit.
An excellent question. I don't know the answer but it is possible to change the pop-up size if you're curious.
Thank, but I'm comfortable with the default behavior for the popup size (and that's relatively easy to change once you find the settings). I'd just like to change the distance from the clicked point from 16pixels to ~40-60pixels. Having over written the default selection highlight, I'd actually be happy to turn off the leader too.
Found this idea on Ideas site. I'm voting it up for sure!
http://ideas.arcgis.com/ideaView?id=087E0000000CxFeIAK#sthash.Os2r5ajs
and this one: http://ideas.arcgis.com/ideaView?id=087E00000004Q0GIAU#sthash.71gGAGao
It looks like the first one you listed is a duplicate and should be merged with the second link. That one s under consideration ..yea ...
Agreed.
Andrea,
Did you ever come across a solution for this issue?
Josie
Just stumbled upon this thread and I'm confused that anyone hasn't come up with a solution yet.
Sure it's possible to enable dragging the popups. With the WAB's Dev edition, that is.
I've used an invisible widget that wraps all the popups into Dojo's Moveable object. The code isn't the most elegant but I guess it could help someone reading this thread. Just make a new invisible widget and paste this into the Widget.js.
define([ 'dojo/_base/declare', 'dojo/_base/lang', 'dojo/dnd/Moveable', 'dojo/on', 'dojo/query', 'jimu/BaseWidget'], function( declare, lang, Moveable, on, query, BaseWidget) { var clazz = declare([BaseWidget], { postCreate: function() { this.inherited(arguments); }, startup: function() { this.inherited(arguments); on(this.map.infoWindow, "show", lang.hitch(this, function(e) { this.makePopupDraggable(); })); on(this.map, "click", lang.hitch(this, function (e) { if (this.map.infoWindow.isShowing) { this.map.infoWindow.hide(); this.makePopupDraggable(); } })); on(query(".esriPopupWrapper .titleButton.prev"), 'click', lang.hitch(this, function() { this.makePopupDraggable(); })); on(query(".esriPopupWrapper .titleButton.next"), 'click', lang.hitch(this, function() { this.makePopupDraggable(); })); }, makePopupDraggable: function() { query(".esriPopup").forEach(function(node) { new Moveable(node); }); } }); return clazz; } );
So not sure if you've found the answer to this yet, but I just got it sorted out today. Hopefully some other people can reference this if they want to get these popups moving.
It's mashing the information in this link: Esri JS API Draggable Popups - JSFiddle with the wacky web app builder file structure.
Started with going to this css file: [app instal]\server\apps\[app#]\themes\LaunchpadTheme\common.css
and making it look like this:
@import url("panels/LaunchpadPanel/style.css"); .esriPopupWrapper .title { cursor: move; } .esriPopup .hidden { display: none !important; }
This makes the pointer turn into the move cursor so your user knows they can move it around.
Then I headed to [app instal]\server\apps\[app#]\jimu.js\utils.js and added the following to their respective locations:
define(['dojo/dnd/Moveable', 'dojo/dom-class'], function(Moveable, domClass)
Then down around line 1089 (or do a find and look for createWebMap) I added some lines to mo.createWebMap:
mo.createWebMap = function(portalUrl, itemId, mapDiv, /* optional */ options) { portalUrl = portalUrlUtils.getStandardPortalUrl(portalUrl); var itemUrl = portalUrlUtils.getBaseItemUrl(portalUrl); arcgisUtils.arcgisUrl = itemUrl; var def = arcgisUtils.createMap(itemId, mapDiv, options); def.then(function (response){ var map = response.map; var handle = query(".title", map.infoWindow.domNode)[0]; var dnd = new Moveable(map.infoWindow.domNode, { handle: handle }); }); return def; };
Let me know if you have any questions, I'll try to answer them.
Tyler Dunn
Thank you 1,000x over for posting this. We have received numerous requests to have the popup be moveable and now I can set that up for our applications.
I really wish ESRI would make it moveable by default or provide a config option of making it moveable, but that's still not the case. Hopefully in the future it will be though.
Thanks again.
Hi Tyler Dunn
Thank you for posting this. Its super helpful for someone like me who has just started on js.
I tried changing my code like you suggested and was only partially successful to replicate. I changed my 'common' file and was able to get the pointer changed into a move cursor.
But upon making subsequent changes on the utils.js file, the WAB stopped displaying any map at all. I went back and took out all the new codes I added and it looks like the addition of
is creating some anomaly.
I should also tell you that I couldn't find 'domClass' or 'dom-class' anywhere else in the code.
Can you please tell if there is anything I am doing wrong?
Thanks in advance.
Shital
Hey Shital,
When you added 'dojo/dnd/Moveable' and 'dojo/dom-class' to the define([ ] part of the code, did you have it in the same order you called it in the function( ) area? Ex:
define([
'dojo/_base/lang',
'dojo/_base/array',
'dojo/_base/html',
'dojo/_base/sniff',
'dojo/_base/config',
'dojo/io-query',
'dojo/query',
'dojo/NodeList-traverse',
'dojo/Deferred',
'dojo/on',
'dojo/dom-class',
'dojo/json',
'dojo/cookie',
'dojo/number',
'dojo/date/locale',
'dojox/encoding/base64',
'esri/lang',
'esri/arcgis/utils',
'esri/SpatialReference',
'esri/geometry/Extent',
'esri/geometry/Multipoint',
'esri/geometry/Polyline',
'esri/geometry/Polygon',
'esri/geometry/webMercatorUtils',
'esri/tasks/GeometryService',
'esri/tasks/ProjectParameters',
'esri/urlUtils',
'esri/request',
'esri/graphicsUtils',
'jimu/portalUrlUtils',
'./shared/utils'
function(lang, array, html, has, config, Moveable, ioQuery, query, nlt, Deferred, on, domClass, json, cookie,
dojoNumber, dateLocale, base64, esriLang, arcgisUtils, SpatialReference, Extent, Multipoint,
Polyline, Polygon, webMercatorUtils, GeometryService, ProjectParameters,
esriUrlUtils, esriRequest, graphicsUtils, portalUrlUtils, sharedUtils)
This worked like a charm Tyler. Thank you so much. Much appreciated!
Mihkel,
I just tried to create this invisible widget, without success. I copied/pasted your code into the Widget.js file, and placed the widget in my widgets folder on the app. No popups appear to be moveable.
You might wanna try the solution posted by Tyler. It worked for me
Shital,
Tyler's solution worked great for me. However, his solution as a work around requires the user to manually configure every app created with WAB after creating/hosting on the server. This becomes very tedious when managing 40+ different WebApps.
With the "invisible" widget, moveable popups could be automatically generated in the app framework without editing intricate files each time the user makes a new WebApp.
Thank you!!!!
Hello Tyler,
I am attempting to implement this code and have a question as to where the respective locations are for the following step:
Thanks so much!
Adam
Nevermind I found the answer reading your response to someone elses question. Thanks so much!
doesn't work with WABde 2.5. Thoughts?
Not sure what version you are referring to but 2.5 looks like this:
define([ 'dojo/_base/lang', 'dojo/_base/array', 'dojo/_base/html', 'dojo/_base/sniff', 'dojo/_base/config', 'dojo/io-query', 'dojo/query', 'dojo/NodeList-traverse', 'dojo/Deferred', 'dojo/promise/all', 'dojo/on', 'dojo/json', 'dojo/cookie', 'dojo/number', 'dojo/date/locale', 'dojo/i18n!dojo/cldr/nls/number', 'dojox/encoding/base64', 'esri/lang', 'esri/arcgis/utils', 'esri/dijit/PopupTemplate', 'esri/SpatialReference', 'esri/geometry/Extent', 'esri/geometry/Multipoint', 'esri/geometry/Polyline', 'esri/geometry/Polygon', 'esri/geometry/webMercatorUtils', 'esri/tasks/GeometryService', 'esri/tasks/ProjectParameters', 'esri/tasks/FeatureSet', 'esri/symbols/PictureMarkerSymbol', 'esri/urlUtils', 'esri/request', 'esri/tasks/query', 'esri/tasks/QueryTask', 'esri/graphicsUtils', 'jimu/portalUrlUtils', './shared/utils' ],
function(lang, array, html, has, config, ioQuery, query, nlt, Deferred, all, on, json, cookie, dojoNumber, dateLocale, nlsBundle, base64, esriLang, arcgisUtils, PopupTemplate, SpatialReference, Extent, Multipoint, Polyline, Polygon, webMercatorUtils, GeometryService, ProjectParameters, FeatureSet, PictureMarkerSymbol, esriUrlUtils, esriRequest, EsriQuery, QueryTask, graphicsUtils, portalUrlUtils, sharedUtils)
Michael,
Still worked fine for me in 2.5
Tyler, I still get 'Cannot read property 'domNode' of undefined' at the query line, and pretty sure the code is identical to yours - ideas?
Hey Charles
Can you post your code for me to take a look at?
Tyler Dunn & everyone - Thanks! This is awesome. Works beautifully.
Tyler, I added a block of code to yours from the original example. To hide the anchor, while you move the window. If anyone wants to do this, use this snippet as below (approx. line 1139, after adding the lines for declare and require)
mo<SPAN class="punctuation token">.</SPAN>createWebMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>portalUrl<SPAN class="punctuation token">,</SPAN> itemId<SPAN class="punctuation token">,</SPAN> mapDiv<SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">/* optional */</SPAN> options<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> portalUrl <SPAN class="operator token">=</SPAN> portalUrlUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getStandardPortalUrl</SPAN><SPAN class="punctuation token">(</SPAN>portalUrl<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> itemUrl <SPAN class="operator token">=</SPAN> portalUrlUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getBaseItemUrl</SPAN><SPAN class="punctuation token">(</SPAN>portalUrl<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> arcgisUtils<SPAN class="punctuation token">.</SPAN>arcgisUrl <SPAN class="operator token">=</SPAN> itemUrl<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> def <SPAN class="operator token">=</SPAN> arcgisUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createMap</SPAN><SPAN class="punctuation token">(</SPAN>itemId<SPAN class="punctuation token">,</SPAN> mapDiv<SPAN class="punctuation token">,</SPAN> options<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> def<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> handle <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".title"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> dnd <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Moveable</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> handle<SPAN class="punctuation token">:</SPAN> handle <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">////// when the infoWindow is moved, hide the anchor arrow //////</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>dnd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'FirstMove'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// hide pointer and outerpointer (used depending on where the pointer is shown)</SPAN> <SPAN class="keyword token">var</SPAN> arrowNode <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".outerPointer"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> domClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>arrowNode<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"hidden"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> arrowNode <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".pointer"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> domClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>arrowNode<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"hidden"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">bind</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">////////////</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN> def<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Is there any way to modify common.css, esri.css, or any of the scripts to allow us to a) prevent the pop-up from being dragged off-screen, or b) prevent the pop-up from re-centering upon clicking the previous or next arrows?
It seems the answer I'm looking for may lie within the Dojo Toolkit, more specifically in constrainedMoveable from dojo/dnd/move. This is what I'm looking at on StackExchange: javascript - How to disable/stop drag action when using dojo/dnd/Moveable? - Stack Overflow
And here's the documentation for drag and drop (dnd) on the Dojo Toolkit Reference Guide: dojo/dnd — The Dojo Toolkit - Reference Guide
Tyler, this is great thank you for sharing your code.
I'm curious, should your code allow the Editor widget popup to be moved or is that a separate issue from what you have resolved above?
